Help Gas leaking
Old May 14, 2016 | 02:41 PM
Mbuschsr's Avatar
Mbuschsr
Default Help Gas leaking
I took my 71 out for a ride this morning. When I got home and pulled in the garage I found gas leaking from the left front fender right behind the wheel. I quickly removed the vent and saw the gas. It looked like it is comming a plastic canister. What is this and should there be gas in it?
Old May 14, 2016 | 02:55 PM
red topless gator's Avatar
red topless gator
Its the charcoal canister, just had that happen to me last weekend. I will be getting rid of it shortly, plug the line and drill a small hole in the gas for a vent./
Old May 14, 2016 | 03:21 PM
Mbuschsr's Avatar
Mbuschsr
How is this supposed to work. Is it a vent from the gas tank?
Should I drill the gas cap?
Old May 14, 2016 | 03:25 PM
mortgageguy's Avatar
mortgageguy
Or, you can rebuild the thing for $20+. The charcoal is saturated and no longer effective. Google how to rebuild evap. Cannnister. There is an excellent write up with photos on the web. Not hard to do. I rebuilt mine last summer.
Old May 14, 2016 | 03:45 PM
Alan 71's Avatar
Alan 71
Hi Mb,
Starting with the 71 model year, Corvettes had an 'Evaporative Emissions Control' system.
The gas tank started using a 'sealed' cap. There was a 'vapor separator' mounted on the driver's side of the tank and a steel line that ran forward along the frame rail to the charcoal canister mounted behind the left side rear apron.
The volatile gas fumes from the gas tank bonded to the charcoal in the canister when the engine wasn't running.
When the the engine was running the large rubber line from the canister lid ran to the engine's pcv valve and on to the carburetor. The vacuum created pulled the volatile fumes from the charcoal bond and they were burned in the engine.
It's difficult to say what's going on with your canister without knowing what parts of the system are in place and in what condition they are.
So do you know what parts of the system are in place on your car?
Regards,
Alan
The Vapor Separator & Hoses
The Vapor Separator
The canister and it's bracket
The canister top and the 3 hose connections
The bottom drain on the canister
Old May 14, 2016 | 03:51 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi and welcome.
This 'vapor separator' is located on the top left side of your fuel tank.
Its function is to allow gas fumes to enter the vapor canister but not raw gas.
You might check that part.
https://willcoxcorvette.com/corvette...or-valve-70-74
Never mind, Alan explained it while I was looking for the part.
Old May 14, 2016 | 05:12 PM
Mbuschsr's Avatar
Mbuschsr
Originally Posted by Alan 71
Hi Mb,
Regards,
Alan
The Vapor Separator
Thanks for the info Alan, I have only owned the car for a few weeks and don't really know anything about this canister. With the info you gust gave me I will try to see how much of the system is intact. I do know that there is a rubber line laying on the manifold that is not hooked up to anything. I did see that it comes from this canister. I don't see anyplace on the carb for this to attach to.
Old May 14, 2016 | 11:22 PM
7T1vette's Avatar
7T1vette
The vapor separator is likely the problem. It is designed to prevent liquid fuel from getting passed to the vapor recovery canister. Obviously, it is no longer doing that task. Replacement is not fun, being located high on the left side of the fuel tank.
The separator also serves a safety function, so it would be best to replace it rather than just cap it off.
P.S. Raw fuel passing through the recovery canister is not [necessarily] a problem. Once the separator is replaced, the fuel captured by the charcoal in the canister will be vaporized and sucked into the intake charge is fairly short order.
Old May 15, 2016 | 07:44 AM
Mbuschsr's Avatar
Mbuschsr
Can this valve be replaced without dropping the tank?
Old May 15, 2016 | 07:55 AM
Alan 71's Avatar
Alan 71
Hi Mb,
I don't think it's ever an acceptable situation to have had any amount of fuel travel to the canister.
The vapor separator can be reached but it's not easy. You might have to drop the muffler on that side to gain some access room.
Once removed the separator can be tested by shaking it. If you hear a 'rattle' that indicates the valve is operational.
Here are a couple pictures showing the rubber hoses (1 large , 1 small) running from the canister to the carburetor.
Regards,
Alan
Old May 15, 2016 | 07:58 AM
imariver's Avatar
imariver
Yes it can, a little tricky but it can be done . . . I replaced mine without removing the tank. However, I do believe that I did remove the muffler.
This same thing happened to me a while back. Every time I would fill the tank and then make a right hand turn, the engine would start to stall out. On one of these occasions, it actually did, when I got out, I noticed gas on the ground right under the vapor cannister.
Old May 15, 2016 | 08:06 AM
imariver's Avatar
imariver
Hi Mb,
One removed the separator can be tested by shaking it. If you hear a 'rattle' that indicates the valve is operational.
Regards,
Alan
Thanks for all this info. For such a simple system it always seems to be a big misunderstood mystery to lots of folks.
Old May 15, 2016 | 08:23 AM
Alan 71's Avatar
Alan 71
Hi I,
You're right it's a pretty simple concept… one moving part…. the ball (?) in the valve in the separator.
The fact that the charcoal is now 40+ years old and that sometimes the hoses to the carb have been disconnected for years, seem to be the causes of most of the trouble folks usually have with it.
Regards,
Alan
Old May 15, 2016 | 10:47 AM
7T1vette's Avatar
7T1vette
The activated charcoal in the vapor canister can become contaminated....but not from fuel in either vapor or liquid form. If necessary, the charcoal CAN be replaced. But liquid fuel coming from the bottom of it is clear indication of a separator unit failure.
Old May 15, 2016 | 11:02 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Glad you answered this first. I can't imagine trying this without dropping the tank but I suppose it is possible.
The Vapor Separator
Alan, your pics never cease to amaze me. The separator on my tank looked so brittle that I was afraid to touch it. I know it would have dissolved if I unbolted it or tried to remove the hose. Couldn't even read the part number
Old May 16, 2016 | 12:31 AM
7T1vette's Avatar
7T1vette
Nothing lasts forever. But a Chevy comes close....
Old May 16, 2016 | 06:44 AM
Mbuschsr's Avatar
Mbuschsr
Thanks All ,
I have checked my car out and it all seams to be there. Except the T fitting at the PVC , that's the hose sitting on the manifold . I will be ordering the new separator valve this week.
Alan, the pictures you posted were a big help. But I must say make me a lot envious. Your car is beautiful .
To Help Gas leaking
Old May 16, 2016 | 10:31 AM
bradleyb66's Avatar
bradleyb66
I think we're all a little envious of Alan's car! I think the only picture I haven't seen is him 'driving' his car, but I think the reason for that is that his car is actually sitting in his living room!
Old May 31, 2016 | 07:53 PM
Mbuschsr's Avatar
Mbuschsr
Hi Mb,
Regards,
Alan
Alan, I bought the parts to change the separator and hook up the lines . I have not had a chance to get the car on a lift yet but I have put the tee in the PVC line to hook the line that was laying on the manafold. When I did that the idle dropped I little. Is this normal?
Old May 31, 2016 | 08:01 PM
Alan 71's Avatar
Alan 71
Hi Mb,
A change in idle speed often does indicate a vacuum leak.
Is the rest of the EEC system in place and the hoses/lines run?
I'd think the idle should be re-set with everything in place that you're going to use after checking for vacuum leaks.
Regards,
Alan
