Transmission Help!
Old May 14, 2016 | 06:47 PM
WICKD 81's Avatar
WICKD 81
Cruising
Default Transmission Help!
I bought a new GM LS3 engine, 430hp for my 1981 corvette. I currently have the stock automatic 350 transmission. I have a few questions:
1. Is there any recommendation for an auto trans I can use with the LS3 that does NOT require cutting into the tunnel, changing driveshafts, and changing crossmembers?
2. The LS3 I bought came with wire harness, throttle pedal, and ECM. My question is will the ECM that came with the engine also control the transmission that I get or will the Trans need a different/separate ECM?
3. Anyone out there have an LS3 mated to their 350 trans? If so, how is the combo?
Thanks in advance, everyone!
Old May 14, 2016 | 11:09 PM
7T1vette's Avatar
7T1vette
Don't know what trans programs are available in that ECM, but you should be able to find out on the web. I can say with some confidence that you don't want to put a THM-350 behind it; I don't even know if you can beef a 350 up enough to be compatible with that engine.
A 4L60-E will probably fit in the C3's trans area (it is essentially a 700-R4 with electronics); that is likely your best bet if the ECM will handle it. The 4L80-E will not fit without some significant modifications. The 4L60-E can be beefed up to your needs without much effort.
If you don't put an electronic trans in the drivetrain, the 700-R4...beefed up appropriately (many aftermarket builders have them already available)...would be a good choice. It has a lockup clutch which SHOULD be turned off when you want to 'pour the coals' to it. The L/U clutch is a good thing for normal driving...and especially for highway driving, so I would suggest a well-built O/D trans with L/U would be the way to go.
Old May 15, 2016 | 01:26 PM
diehrd's Avatar
diehrd
He has to use an electronic trans if he wants it to be simple. 4l60e . the 4l80e fits like a glove as well ( I have one in my 1980) but for your 430hp the 4l60e is plenty .
You will mod the cross member and you will change drive shaft length . BTO sells a cross member plug and play for the 700R4 which works perfect with a 4l60e
Old May 15, 2016 | 01:30 PM
WICKD 81's Avatar
WICKD 81
Cruising
Thanks so much!
Old May 15, 2016 | 04:11 PM
WICKD 81's Avatar
WICKD 81
Cruising
Found a 4L60e out of a mid ninety caprice, will that work? And would the computer from my LS3 manage the engine and trans or do I need a separate computer for the trans?
Old May 16, 2016 | 10:23 PM
7T1vette's Avatar
7T1vette
You will have to get some expert advice about whether that transmission, as it is, will handle that kind of torque/power. Research it well; you don't want it to 'bite the dust' early. If you know someone in the transmission repair/rebuilding business (local...not a national chain store), they might be able to tell you what needs beefing up--or maybe be able to beef it up for you. I'm sure it will be a good trans, once capable of handling that new engine. And I'd bet it will integrate with the engine and ECM you already have.
To Transmission Help!
