1982 blower motor replace
Old May 19, 2016 | 08:06 PM
terry82's Avatar
terry82
Default 1982 blower motor replace
My blower motor in my 82 is making a lot of noise. I think its time to replace.Any tips on changing this?
Old May 19, 2016 | 08:45 PM
procketus's Avatar
procketus
C4 of Year Finalist (appearance mods) 2019
2017 C4 of Year Finalist
Not hard at all. Unplug the wires and A few screws and remove it. A lot of guys have converted to the C4 blowers but it is more involved. Need to make a spacer as the fan cage is bigger. When I did mine I just took the cage off the old one and swapped it to the new one.
Old May 19, 2016 | 08:56 PM
terry82's Avatar
terry82
It looks like I have to remove the coolant tank and maybe the ac line .The factory fan is fine for me .I have sealed up several of the air lines at the joints in the car .
Old May 20, 2016 | 04:51 PM
terry82's Avatar
terry82
okay I got it changed.Taking out the coolant tank was a pain .This would have been a good time to have one of those flexable cameras.would have liked to look inside hole where the wheel goes to look for dirt or to see the heating core.i did blow it out with air.I did add a better ground wire.Its been posted here that it can help .Took me 2.5 hours with cleaning of old fan blade and better ground wire.
Old May 20, 2016 | 05:03 PM
fishslayer143's Avatar
fishslayer143
A vacuum cleaner w/hose would get the leaves and debris out of there
Old May 20, 2016 | 06:09 PM
terry82's Avatar
terry82
There was not much dirt and leaves in there.i expected more.
Old May 22, 2016 | 06:50 PM
DUB's Avatar
DUB
YES...when the blower motor is OUT...that is the time to check the front face of your evaporator core and see how plugged up it is.
I use my bore scope and look and then use my modified tube on my vacuum cleaner to vacuum out the debris that sits at the bottom of the evaporator core where it is really hard to see it.
DUB
Old May 22, 2016 | 07:21 PM
terry82's Avatar
terry82
a scope would have been great.when I used my air hose there was not much in there .A scope would have proved it.My air flow is good.
Old May 22, 2016 | 07:25 PM
DUB's Avatar
DUB
SUPER GOOD
DUB
To 1982 blower motor replace
