Whats this ?
Old May 26, 2016 | 07:20 AM
rogergcam's Avatar
rogergcam
Default Whats this ?
I'm resurrecting a 1972 LS-5, with the 454 block. There is this small pulley located on the lower, drivers side of the block. It does not seem to be "attached" to anything. I can just get my fingers on it from the top, and it rotates freely.
What is it for?
Help PLEASE!
Old May 26, 2016 | 07:42 AM
emccomas's Avatar
emccomas
It is an idler pulley used on big block cars with A/C.
As I recall, it provides additional spinning force on the water pump. The water pump by itself could slip when the A/C was engaged.
Old May 26, 2016 | 07:43 AM
gbvette62's Avatar
gbvette62
It's the idler. There should be a belt running from the inner grooves of the water pump and crank pulley's, to the idler. It was used on all 68-74 big blocks with air conditioning, but not non air cars.
JV just beat me in with the answer!
Old May 26, 2016 | 11:02 AM
sullyman56's Avatar
sullyman56
What is it for?
Help PLEASE!
I'm looking for one if you're not planning on using it. PM me and we'll discuss it.
Old May 26, 2016 | 11:37 AM
Alan 71's Avatar
Alan 71
Hi r,
Here's the page from the AIM that shows the belt routing for the idler pulley on engines with a/c, (C60).
Regards,
Alan
Note the belt for the idler is in addition to the others. 3 grooves on the water pump pulley.
Old May 26, 2016 | 02:53 PM
71 Green 454's Avatar
71 Green 454
What is it for?
Help PLEASE!
From looking at the photo, it looks like the belt from the crank to water pump is there and the idler pulley is all the way in. There are holes in the pulley to provide access to the lock bolt you loosen first to adjust the pulley.
I like to use a Gates 7320 belt so the idler pulley isn't in so far.
Old May 28, 2016 | 03:16 PM
rogergcam's Avatar
rogergcam
Default Pulley--thanks
Thanks to everyone for the help! Much appreciated!
Old May 28, 2016 | 07:02 PM
530planeman's Avatar
530planeman
What is it for?
Help PLEASE!
It's a little tricky getting that belt on as That pulley runs on the back side of that short belt make sure you have 4 studs in water pump to hold water pump on . good luck
Old May 28, 2016 | 07:35 PM
The13Bats's Avatar
The13Bats
while of the subject of bb belts perhaps one you can shine some light on this one,
On my bb there is a belt that goes from water pump to crank, no idle pulley,
it is shown in a few of the pictures Alan posted above,
So what is the "correct" way to remove and install that one?
Being that belts do stretch over time and it appears the install is a force stretch it on idea and no idle pulley for tension doesn't that belt become somewhat useless as time passes?
Old May 28, 2016 | 07:52 PM
530planeman
Hey Bats
Remove all the belts ,remove nuts and washers on fan to water pump ,put short belt on crank pulley then pull up on water pump pulley and slide over studs on water pump.These belts are so short they don't stretch much .Make sure studs on water pump are not too long as it will be difficult to get pulley over and spin engine over a little to center water pump pulley before final tighten
Now that I have confused you have fun.
Wes
Old Jun 3, 2016 | 01:08 PM
Mike 92LX's Avatar
Mike 92LX
Roger keep in touch. I will help
To Whats this ?
