1980 corvette engine shuts down
Old Jun 1, 2016 | 11:11 PM
Curacaocorvette's Avatar
Curacaocorvette
4th Gear
Default 1980 corvette engine shuts down
Hello from Curaçao,
I have a 1980 Corvette with a 5.7 litre engine. When I am standing in traffic with my foot on the brake and the car in Neutral it runs fine. However when I place the car in drive and put my foot on the brake it shuts the engine off after a few minutes.
Can anyone tell me what the probable causes could be and how to fix it?
Thanks in advance
Old Jun 2, 2016 | 12:47 AM
vettebuyer6369's Avatar
vettebuyer6369
This is the Parts For Sale classifieds. Moving thread to General discussion.
Old Jun 2, 2016 | 07:36 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
When was the last time the car was tuned? What is the idle speed with the car in Drive? Why are you putting the car in Neutral at a stop light?
Old Jun 2, 2016 | 01:26 PM
Curacaocorvette
4th Gear
Default Reply
The car got a tune up last week. I drive about 50 mph. When I am standing at the stoplight I leave it in Drive but the car shuts off so I need to put it in Neutral. When I do this it the motor keeps running.
Old Jun 2, 2016 | 02:17 PM
Easy Mike's Avatar
Easy Mike
At normal operating temperature, in Drive, the car should idle about about 650-700 rpm. In Neutral or Park, that figure will bump up a little.
Old Jun 2, 2016 | 02:30 PM
gdm78vette's Avatar
gdm78vette
You say it shuts off after a few minutes when in drive and foot on brake so are you saying it does run for a while before stalling? Or does it stall as soon as you get to idle in drive? Does the car have AC? Maybe the fast idle solenoid that is supposed to speed up idle when the AC starts isn't working? When you're in neutral does the idle speed change as the AC kicks in and out?
Old Jun 2, 2016 | 03:22 PM
fishslayer143's Avatar
fishslayer143
You may have a carb flooding issue or your idle is just set too low
Old Jun 2, 2016 | 04:47 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Help us (me?) with your definition of "Shuts Off"
Does the engine "Shut off" like you turn the key off or does it run a bit bajigadity then stall out?
My guess is that a combo of adjusting the idle speed, rich/lean or a bump in the timing could do a lot for your idle.
Your trans in drive at a stop will drag 150rpms easily out of the engine.
Old Jun 2, 2016 | 04:58 PM
MelWff's Avatar
MelWff
Default Stalling
Why arent you taking the car back to the person who tuned it?
Curacaocorvette
4th Gear
It does sound like an idle issue. On Saturday I'm going to get it checked out. Fingers crossed..
Thanks for all your help so far.
Old Jun 2, 2016 | 07:35 PM
Curacaocorvette
4th Gear
When I have it in Drive and standing at a stop light with my foot on the brake it works fine for a short while, then it starts to splutter before the engine dying on me.
To 1980 corvette engine shuts down
