'68 Door Panels on '74
Old Jun 3, 2016 | 03:48 PM
Richard Daugird's Avatar
Richard Daugird
Default '68 Door Panels on '74
I thought I'd asked this before but search did not find it. I have arthritis in my left hip and have to work my leg back and forth frequently while driving, especially on long trips. The door pull bumps my knee while doing this. I have removed the door pull on that side and now I am more comfortable. I was thinking I could swap out to '68 door panels(I like the way they look as well)when I get around to changing the interior color. I don't mind drilling new holes in the door if necessary, the car is not stock and will never likely be stock. I have power windows.
Old Jun 3, 2016 | 04:15 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The panels will otherwise fit. For 74, the window wipe is stapled to door panel; for 68 it is a separate part. You may be able to add the 74 window wipe to the 68 panel. 68 panels are a little thicker in the shoulder area. I'm not sure you will get additional space for your knee with the 68 panels.
Since the 68 panels are one year only, finding a good used pair at a reasonable price might be a real PITA.
Old Jun 3, 2016 | 05:01 PM
Richard Daugird
Now I know I asked about this somewhere. I will be buying a complete kit when the time comes. Thanks for the info. I'll try to find a '68 I can sit in in the meantime to check comfort.
Old Jun 4, 2016 | 06:04 PM
1Fordman's Avatar
1Fordman
As Mike stated above, you'll lose about 1 to 1-1/2" of interior width in the shoulder area. And you'll have to get creative to have the felts work correctly. The 68's have a seperate metal frame that bolts to the door frame.
Old Jun 4, 2016 | 06:31 PM
Richard Daugird
Thanks fellas.
Old Jun 4, 2016 | 06:34 PM
loup68's Avatar
loup68
Army
If you have a 68, it is very reassuring to have the 68 interior door panel shoulder support if you take some spirited corners like I usually do!!! That is if you do not have very broad shoulders. Lou.
Old Jun 4, 2016 | 07:04 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Richard-
I hate to go against the grain on this... but the 68 door metal frame was different than the 1969 and newer. To attach the door panel to the car you'd have to switch and install the 1968 inner wipe assembly, I'm not so sure how that would work out with a later model door.
I'm sure the panel will fit on the door but the 68 panel doesn't have the wipe made into it so you'll have to figure out how to modify the door to accept the 68 wipe and/or just run the panel without one.
The next question would be what would you attach the upper portion of the 68 panel to. The 68 panel used the upper wipe reinforcement as a point of attachment...
I'd be interested to see how this works or if someone else has crossed this bridge. I do know I've got a 68 customer with later model door panels on his car but going forward seems easier than going backwards...
IMHO..
Willcox
Old Jun 6, 2016 | 11:58 AM
Richard Daugird
I imagine I can make it work. Maybe figure out a way to reinforce the top and not use the wipe, don't plan to do much rainy day driving.
Old Dec 23, 2020 | 10:05 AM
Richard Daugird
Four and a half years later, the car has been wrecked and repainted, engine blown and replaced, finally up and running! As soon as I finish the brakes, I will start on the interior. I'll let y'all know how this door panel swap goes.
Old Aug 17, 2022 | 12:09 AM
jkp2021's Avatar
jkp2021
Did you end up swapping 68 for 69 door panels? If so, how did it go? Doing a frame off now on a 68 and starting a parts list. Door panels are on it already.
Old Aug 17, 2022 | 10:17 AM
Richard Daugird
I got a pair of '68 panels, but they are not yet installed.
Old Aug 17, 2022 | 10:58 AM
jkp2021's Avatar
jkp2021
Where did you get your panels from? I'm researching now to find reasonable options.
Old Aug 17, 2022 | 11:01 AM
Richard Daugird
I don't remember, Eckler's, Corvette America, one of the big Corvette parts houses. I think I read that they are all made by Al Knoch.
Old Aug 21, 2022 | 05:34 PM
loup68's Avatar
loup68
Army
As far as I know, both Al Knoch and Corvette America (now top flight automotive) make 68 door panels. Lou.
Old Aug 21, 2022 | 07:28 PM
gbvette62's Avatar
gbvette62
Correct, Knoch and CA both make their own panels, and they both make them in the US.
To '68 Door Panels on '74
