Engine vac lines
Old Jun 9, 2016 | 08:15 PM
ATIS's Avatar
ATIS
Default Engine vac lines
Is there a vac line kit for all the lines around the carb? Or are those the heater and light lines? Chasing a rough idle and with 41 yr old vac lines I figure they are a good place to start.
Old Jun 9, 2016 | 09:43 PM
croaker's Avatar
croaker
I was having same issue. After I capped the main line going to headlights it improved. Headlights were and are working pretty good still changing and inspecting lines in that system.
Old Jun 9, 2016 | 09:47 PM
ATIS's Avatar
ATIS
Ok, so I will order the lights kit and do them first. Then the heater lines. Joy. Lol
Old Jun 9, 2016 | 10:42 PM
bj1k's Avatar
bj1k
I just went through this with my 72 and it turned out to be a vacuum leak in the brake booster . Mine was such a small leak that it was hard to detect and the brakes seemed to work fine but with the new booster the brake booster is twice as sensitive and takes very little effort to stop . Isolate one section at a time and test for leaks .
Old Jun 9, 2016 | 10:49 PM
ATIS's Avatar
ATIS
Will do. Are the only vac lines the lights and heater? I can only find kits for those two areas. I was hoping to get the lines that are color marked to keep her looking original.
To Engine vac lines
