68 Fuel return line
Old Jun 13, 2016 | 06:57 PM
flyeri's Avatar
flyeri
Default 68 Fuel return line
My car does not have one and I want to add a fuel return. Thinking through the possibilities of adding the line along the frame to the tank. How about some ideas from those who have done this with the body on. Rubber hose, braided hose, solid oem style? Looks like the oem style would need a splice. Suggestions are welcome. Thanks
Old Jun 13, 2016 | 07:42 PM
Corvettes by George's Avatar
0Corvettes by George
Former Vendor
Humm?
No return line.
I guess you realize that the only '68's without a return fuel line were Holley carb equipped engines (427's--either 400/435 HP tripower, or the L88)
U might want to do some research on how your vette was origanaley quipped?
Old Jun 13, 2016 | 08:45 PM
flyeri's Avatar
flyeri
Originally Posted by 1960fi
Humm?
No return line.
It was a 427 but it makes no difference now. That engine is loooong gone. It had a 454 solid lifter, too much cam for a fun driver, very leaky motor when I got it. Now a ZZ454 that is much happier with a TKO600 as an all day driver. Wife is happy because she does not smell like gas and weed eater exhaust at the end of the day. I like to keep the car at least period correct but that is about it.
Anyway, now that summer is here I have the problem of fuel heating up and idling rough and a bit difficult to start when hot after sitting for a bit. I liked Lars fuel return solution and that is where I'm headed.
Besides, a PO put a Stingray emblem on it so it's not worth anything any more. :-)
Old Jun 13, 2016 | 08:48 PM
530planeman's Avatar
530planeman
If you take a stock return line and split it where it goes thru the cross member next to the frame you can make it work .If you have a flare tool you can get a union at the parts store if not get a male barbed fitting and double clamp both sides .
Would not suggest rubber or braded under the body .
Wes
Old Jun 13, 2016 | 09:16 PM
flyeri's Avatar
flyeri
Wes
So threading it up the frame over the axle is doable? That looked tight. I'll have to take a closer look.
Old Jun 13, 2016 | 10:56 PM
73 Rat's Avatar
73 Rat
Definitely do-able...I ran both new lines in two sections, bent them by hand, and spliced them (with fuel line & clamps under the frame) all with the body on ...
Good Luck!
Mike
Old Jun 14, 2016 | 02:13 PM
TheFixer's Avatar
TheFixer
You can also use nylon lines. I think they rent the tool to insert the ends, but I have the tool so I never looked into it. Just press in 2 steel barb splices at each end after you figure the correct length. 3/8" and 5/6" are easy to get, but I couldn't find anyone with the 1/4" line so I used 5/16" for the return. I used the original clamps and bent them so they fit around he larger line.
Old Jun 14, 2016 | 05:06 PM
flyeri's Avatar
flyeri
Thanks for the input. I'll consider the nylon option too.
Old Jun 14, 2016 | 07:05 PM
DUB's Avatar
DUB
Originally Posted by 73 Rat
When I get Corvettes in my shop with the fuel lines looking like this....I just shutter and ask them if they want their car on fire or not.
Rubber hoses hanging down are accessible for something to grab or cut them is NOT wise....and I can tell you that one morning I came into my shop and the gas fumes about knocked me down... I ran and shut the power down in the shop....and FOUND that the car I brought in the day before had this set-up on it and the hoses leaked fuel out on the ground.
SO..do what you want.
DUB
To 68 Fuel return line
