1972 lt1
Old Jun 14, 2016 | 10:13 PM
ramastreet's Avatar
ramastreet
1st Gear
Default 1972 lt1
I am considering the purchase of a 1972 LT1 Corvette. This is a solid lifter engine. My two questions are as follows: How often do solid lifters need adjusting and what numeric or letter codes identify an LT1 engine. My background is centered around Pontiacs so any help in identifying a true LT1 Corvette is appreciated. Thanks, Joe Slatkiewicz, Taunton, MA.
Old Jun 15, 2016 | 06:16 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Joe, The 72 LT1 will have an L as the 5th digit in the VIN. Engine suffix should be CKY, CRS or CRT for an LT1 depending on options. (ZR1 CKZ).
Solid lifters should be adjusted when they start clacking. You will hear it. How often you adjust depends on how hard and how often you drive it.
Old Jun 15, 2016 | 08:55 AM
Alan 71's Avatar
Alan 71
Hi r,
Welcome!
First Post!
And looking at an LT-!. VERY NICE!
One of the first things you'll want to check after looking for the "L" on the vin tag on the a-pillar is the stamp pad on the engine.
You'll be looking for several things:
The 'assembly stamp' will contain the date the engine was built and a 3 letter 'broadcast code' indicating what 'configuration' the engine was built in.
The 'vin stamp' will identify the car this engine was first installed in and should match the vin tag on the a-pillar information.
You'll also want to consider the appearance and condition of the surface of the stamp pad to try assess whether it has been 'worked on' since the block was first machined.
The letter 'L' on the vin tag will tell you if this car was built as an LT-!, while the information on the engine stamp pad will help you determine if it still has it's original engine.
Good Luck!
Regards,
Alan
The pad location in front of the right side head.
Old Jun 15, 2016 | 12:17 PM
Dirty Dalton's Avatar
Dirty Dalton
Trust me, I've years of experience behind me. You'll be rasseling with those stupid things every week. You don't want this thing, believe me.
Do you have the number for the seller handy?
Old Jun 15, 2016 | 04:10 PM
MelWff's Avatar
MelWff
I have a 70 LT-1 short block and adjust valves every 12,000 miles which is many years for me. There is a paper on how to correctly adjust the valves cold.
http://www.lbfun.com/warehouse/tech_...n/SBvlvadj.pdf
Old Jun 15, 2016 | 04:39 PM
Barry's70LT1's Avatar
Barry's70LT1
46 years with my '70 LT-1, adjust valves every 10K - 12K also. Definitely not a frequent hassle.
Old Jun 15, 2016 | 05:52 PM
Dirty Dalton
Thank you for all the 'thank yous', but who are you going to believe (not me, I hope!)
Old Jun 16, 2016 | 10:08 AM
Alan 71's Avatar
Alan 71
Hi rs,
You'll probably be tightening the screws on the Holley fuel bowls a lot more often the you'll be adjusting the valve!
Thankfully it's a lot quicker and easier!
Please lot us know about the car if it becomes yours!
Regards,
Alan
To 1972 lt1
