Hi i would like to know if there is any difference between a 1971 small block & big block alternators is the only difference with the pulley? can the B/block pulley be mounted on the s/block alternator . thanks for your time .
Mooser gave the correct 1971 numbers and that they are 10SI; internal regulator. The shaft should be the same to swap your pulley. Keep in mind these are real simple to rebuild. Need a vice, some hand tools and a parts kit from ebay (not me http://www.ebay.com/itm/New-10SI-Del...FV66N-&vxp=mtr ) or elsewhere. Good luck.
