black smoke drivers side
Old Jun 18, 2016 | 09:38 AM
colinmartin427's Avatar
colinmartin427
8th Gear
Default black smoke drivers side
1970 454 bb
hi guys
just rebuilt carb ,but rebuilt because it was running too rich and couldn't seem to set it up anyway just installed it and I have the same problem masses of black unburned fuel coming out of drivers side exhaust I have just changed the distributor cap coil and wires to be safe .I have to be honest I am gutted , any ideas? don't mind working on the car but it would have been nice to at least enjoy it a couple of times before I start.
Old Jun 18, 2016 | 04:27 PM
Alan 71's Avatar
Alan 71
Hi cm,
Since you've only had the car for a brief time….when did this smoke and un-burned fuel become an issue?
Before you tried to adjust the carb?
You say that you changed the cap/coil/plug wires… did you check the condition of the spark plugs? are they firing?
Regards,
Alan
Old Jun 18, 2016 | 07:35 PM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
Is it blowing black smoke while driving or sitting in the garage .If it is sitting in the garage and blowing black it sounds like your idle mixture to rich or choke stuck on if while driving you might have to re jet your carb.
Old Jun 19, 2016 | 10:31 AM
colinmartin427
8th Gear
thanks guys I will look into it ,is it possible that its only on one side?
To black smoke drivers side
