Which steering system and a/c?
I have to address the steering. I park in a side load garage and no p/s it is an awful PIA to put the car where I want it. I don't know much about steering systems though and I'm not sure whether to just do A) p/s conversion, B) rack and pinion conversion or C) spend twice the dough and do rack and pinion along with power? Some one please help me here as I'd like to order parts and get this done ASAP!
I also need A/C installed. Anyone particularly happy with a specific vendor/system? This looks like a pretty complicated install and I'm considering having this done instead of tackling it myself. Is this a job best left to pros?
Thank you,
Kevin
Vintage Air and other aftermarket providers offer add-on AC.
Welcome!
First Corvette! AND it's a 68 427 convertible! Well done!
If that's it in the photo, and based on your comments about you and the car, I'd say installing a stock power steering system is an o.k. idea but an aftermarket a/c system not quite so o.k..
Good Luck!
Regards,
Alan
Nice buy for sure!!! Post more photos, please. 68 is my favorite year, on my second one now.
My 2 cents: if yours is an all original L71, this is a highly desirable Corvette. I would leave it as is, or certainly only make easily reversible changes. Also IMHO, I suggest not doing anything for 6 months or so and enjoy it as is for awhile until you decide where you want to go with it. Factory power steering will work just fine I think if you decide to go that route.
Have Fun!!!
BTW, on a/c, I installed Vintage Air on both of the 68's I owned but they both did not have the originality nor the desirability of yours. If I had yours, I would install the original factory air setup which will work ok.
That is it in the pic. I'll post more.
I will take your advice on the original power steering setup and do that. I'll get those parts ordered today and from what I've read here expect that conversion to go smoothly.
If I don't install a/c I can't drive the car here in Houston except for a couple of months per year at most. So it's a must. I realize that a car is only original once, but this one has been repainted in it's past, and the engine, transmission and diff have all just been rebuilt as well so it doesn't really qualify as a survivor. I figure any change I make can be undone at this point, am I wrong?
I got an estimate yesterday for Vintage Air installed at $3800 plus tax. So with that, looks like I'll be doing it myself. I plan to install the compressor one day, then the condenser one day, and keeping taking baby steps where I can leaving the car drivable during the lifespan of the project as much as I can.
Thanks again for all of the input!
It looks like a nice one!
Even though it may no longer be a car that would do well in Survivor or Bowtie judging I'd still be considerate in deciding just what you do or don't do to it.
Good Luck!
Regards,
Alan
Beautiful Corvette!!! Much thanks for the photos!
Yep, I can relate for the need for a/c in Lafayette or Houston either one,
You might want to check out some Vintage Air installs and see how they look before you proceed. Vintage Air works great though! Wow, good to know the price for a VA install, makes sense though. I have installed 2 VA systems in 2 different 68's now and pretty straightforward I think, just carefully follow VA's instructions which are good I think. Also, VA tech will help you, just call. And of course, this forum will help too. Note, on the charge (which I did myself), follow the VA instructions to the letter, you can get 28oz in if you follow their instructions completely and get the designed cooling. Good luck and hope this helps. VA is reversible except for a small cutoff in the firewall and cutouts in your inner fender (for a non a/c Corvette). Save all of the old parts of course as someone may want them.All the best!
BTW, almost forgot, scroll down about 1/2 way and you can download and study VA installation instructions (if you have not already) and understand the install procedure before you buy:
http://www.vintageair.com/GM%20SureF...structions.asp
Power steering parts are ordered already, some fro Borgeson, some from Summit. Found the best pricing for Borgeson parts using both vendors. The steering box is out of stock though, hoping I don't have to wait too long.
Thanks all!
