Factory Sidepipes
Old Jul 2, 2016 | 12:21 PM
mpro71vette's Avatar
mpro71vette
Default Factory Sidepipes
I did a search but couldn't find anything. I'm installing factory sidepipes. I did a fit and it looks like I don't have to cut anything off the front fender. Now for the covers I will, I thought I would have to for the sidepipes, is this correct? Also the sidepipes are right against the frame, is that correct? Should I paint the frame with high temp paint? One more question, on Wilcox paper on fitting it said I would need a spacer exhaust pipe. I bought them but the pipes fit fine without them, is this correct?
Thanks for the help!
Old Jul 2, 2016 | 12:45 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
My sidepipes are not against the frame. There is enough space to fit my fingers between them. If by spacers you mean the rubber disks, they should be installed between the large metal tab on the sideppes and the frame. That may help with your spacing.
Tried to get a pic but it's pretty low to the ground. If it becomes a problem, I can jack it up and get pics for you.
Old Jul 2, 2016 | 12:47 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Nothing to cut for the pipes.
If they are right against/touching the frame something is wrong/missing as there should be attaching hardware.
No paint required.
No idea what a "spacer exhaust pipe" is - pic or link helpful.
When fitting the covers it helped to raise the side of the car up (enough to remove the wheels). This gave the clearance needed to manipulate the front cover attaching point over the pipes. Took several test fits.
Hardest part is adding the attaching hardware to the car for the covers along the body.
Old Jul 2, 2016 | 01:09 PM
mpro71vette
Thanks guys, by spacer I mean at the exhaust manifold end, Its like a heat riser but doesn't have the center. I just tried fitting the spacer and it didn't fit.
Here is what I'm talking about for a spacer
http://www.ecklerscorvette.com/catal...acer&x=14&y=23
Thanks for the help, I check the mounting of sidepipe to see if I can get my fingers between.
Old Jul 2, 2016 | 01:15 PM
Hammerhead Fred
rickscamaro redirect form that link was no help.
If you're talking about the exhaust doughnuts you'll be wanting those when you start it up. If they don't fit you may have the wrong size or might be missing the adapter.
Old Jul 2, 2016 | 01:20 PM
mpro71vette
try this one:
http://www.parts123.com/corvettecent...50g&ukey=12249
Old Jul 2, 2016 | 01:23 PM
mpro71vette
I checked my other side pipe and it is longer connecting to the exhaust manifold, if my right side was like that it may work. Do you think they sent me the wrong size or screwed one side up?
Old Jul 2, 2016 | 01:25 PM
mpro71vette
Are you guys using factory exhaust manifold?
Old Jul 2, 2016 | 01:41 PM
Hammerhead Fred
Same thought.
If stock manifolds then passenger side has a heat riser valve.
You either use the stock heat riser OR replace it with the one you linked to which has no valve (so it's just a spacer now).
Old Jul 2, 2016 | 03:55 PM
mpro71vette
anyone else?
Old Jul 2, 2016 | 06:45 PM
GUSTO14's Avatar
GUSTO14
This is what your system should look like.
The spacer/exhaust heat riser (in this case the spacer) has a flat side, and a side with a tapered seat.
photo courtesy Paragon Corvette Reproductions
https://www.paragoncorvette.com/p-35...r-rh-2-12.aspx
The flat side goes against the manifold and has a thin flat gasket between the manifold and the spacer.
https://www.paragoncorvette.com/p-35...sket-2-12.aspx
The tapered side uses a standard exhaust donut (tapered on both edges) between it and the header pipe (on both header pipes)
https://www.paragoncorvette.com/p-35...onut-2-12.aspx
Without the exhaust donuts the pipes will appear to fit together, but you will end up with a pretty significant exhaust leak. The exhaust donut alignment sleeve on the drivers side keeps the donut aligned as you are tightening the header to the manifold and slips into the header pipe as well as up into the manifold.
Good luck... GUSTO
Old Jul 2, 2016 | 08:13 PM
mpro71vette
Good luck... GUSTO
Thanks! This is just what I needed! It clears a lot of things up!:
Old Nov 24, 2016 | 06:54 AM
buelldude's Avatar
buelldude
Default ?
first vette, before the deal was made. checking it out.
Good morning, Happy Thanksgiving
This is my first post, first vette (got it 4 days ago) and it has some issues, exhaust to start. The above pic is a big help but brings up some questions.
Do I need the heat riser?
Why doesn't the other side have it?
After digging in to this problem, I need parts!!!! I don't have any sources for parts for this car yet------- anyone have a list of sources for parts?
1972 Corvette 350 sb/ auto and seems to have all the parts from the factory???
Old Nov 24, 2016 | 07:15 AM
Alan 71's Avatar
Alan 71
Hi b,
Welcome!
Happy Thanksgiving!!
Car looks like a nice one!!!
The purpose of the heat riser is to shorten the time it takes the engine to warm up enough to reach operating temperature by directing heat from the exhaust through a passage in the intake manifold below the carburetor.
An engine with a carburetor that has an operating choke and an operating hear riser will drop to normal operating rpm more quickly than one without.
The exhaust gas circulates across the manifold from the right to left side so there would be no need for a heat riser valve on the left side.
On many engines this heating process results in the orange paint on the manifold darkening in the area of the crossover because of the increased heat in that area.
A few good sources for parts are:
ZIP Products
Corvette Central
Paragon Reproduction
Willcox
Regards,
Alan
The heat riser installed.
An example of the darkened area the heat passage in the manifold causes in the engine paint.
Old Nov 24, 2016 | 07:23 AM
buelldude's Avatar
buelldude
Default ?
I will go check those places, I need the manifold bolts first.
Old Nov 24, 2016 | 07:32 AM
Alan 71's Avatar
Alan 71
Hi b,
Those vendors will have the manifold bolts too.
If you're talking about the bolts to fasten the manifolds to the engine notice that there are special washers and 'french locks' used on the bolts.
If you're talking about the bolts for the exhaust flanges notice the 'studs' are longer on the side with the heat riser than on the left side.
Regards,
Alan
Old Jan 4, 2017 | 07:12 AM
NMT1957's Avatar
NMT1957
Is the spacer they are talking about the one that goes between the transmission and the frame? I have 3 1969 with side exhaust. The bracket that the regular exhaust attaches to is under the transmission. It is somewhat of a "T" shape. That has to be removed and a small flat spacer gets installed in it's place. All of the parts suppliers sell them.
Also, yes the fender was cut out on all 1969s with side exhaust that I know of. It is a very crude cutout. I have a picture if you need it. There is also insulation between the frame rail and rocker channel, again I have pictures if needed.
Old Jan 4, 2017 | 07:35 AM
Alan 71's Avatar
Alan 71
Hi Ned,
I believe the 'spacer' that's talked about and shown in this thread is the one located at the right side exhaust manifold that some people choose to use in place of the heat riser. About 1" thick.
The one you mention fewer people even know about. It was used under the rear transmission mount to replace the exhaust hanger that was not installed on original N-14 cars. I believe it's purpose was to keep the angle between the engine/transmission and the driveshaft the same on an N-14 car as on an under-car exhaust equipped car.
Regards,
Alan
Old Jan 4, 2017 | 08:06 AM
Don Rickles's Avatar
Don Rickles
2017 C3 of Year
The heat risers main purpose was to help eliminate or reduce hydrocarbons exiting the vehicle through the exhaust pipe. Reducing the time from start up to operating temperature was one method. It also returned/slowed exhaust gases, to be "reburned" reducing the harmful outgoing hydrocarbons.
Edit: The rocker moldings were "trimmed" slightly where the pipes crossed the frame rail, on my '72 when I bought it....
To Factory Sidepipes
