Q-Jet running very rich.
2016 C2 of the Year Finalist
I'm working on my deceased brother's 72 350/200/4-speed, all stock, for his widow. He was the second owner since 1980. It's been sitting for six years but with a new battery and prime, started right up. There were no brakes so I bled and fixed them. Changed oil and filter. Drained the gas and put in new. Tank looked great inside. Car runs good so carb air mix is okay I think.
The carb (original) ran rich even when he was alive and he had it rebuilt twice but it still had exhaust that smelled like the choke was on. It still does stink! And the choke is full open after warm up.
I'm thinking the first owner may have messed with the jets inside the carb which has caused the problem ever since he owned it and were not replaced by the rebuilders. Is there a way for me to check this? Can original size jets be purchased? Where should I start?
have you started by adjusting the mixture screws on a fully warmed up engine?
When it runs and drives does it hesitate when you put your foot in it? What is it idling at, Rpms? Remember there is no catalytic converter to scrub the exhaust and it will smell like horsepower candy.
Thanks.
There's no hesitation when I accelerate hard and it idles at 800 rpm as measured by the tach. I have a 64/327/300 and know that " no converter horsepower candy smell" (). This smell is much richer, similar to my 64 at warm up with full choke, but the choke is off. That's why I'm thinking something inside is dumping extra fuel while it runs warmed up. I don't know enough about the workings of these carbs to figure out what might have been altered by a PO, if anything, or what might be wrong to cause this.
Thanks.
Thanks.
I agree.
That is the first place I would look. Make sure you get a float that will handle the modern gas and make sure it is not set too high.
There is a person on the internet that specialized in rebuilding all sorts of Quadrajets, stock and performance modifications. You would have to look them up. They have great right-ups on how they work, etc. They had the right parts and such and they were great at answering questions.
I would look closely at the power valve inside also. I don't think it would cause those symptoms but I would look at it anyway and rebuild it as well.
Look for signs of an internal gas leak. If you take it apart, put the main body parts on a flat surface and make sure they are not warped. People over tighten the screws and they get warped. Good news, you can usually fix them. That company that I mentioned had a fixture for that.
As I recall, you an take the air cleaner off while at idle and look down the primaries, it is possible to see if excess fuel is dribbling off the primary venturies. You can't see the secondaries. This is something that might help confirm your problem.
Good luck and let us know how it turns out.
Just adding this. Look at the spark plugs and make sure they are correct. I would consider using a slightly hotter plug. This is something I have heard others doing.
Last edited by tfringo; 07-13-2016 at 10:44 AM. Reason: additional information added
dkleather (07-13-2016)
I found my float problem by looking down into the carburetor and seeing excess fuel dribbling in. If you do replace the float and needle valve, I would also replace the pump plunger that can handle ethanol.
Hi again,
Just wondering if it still has its smog system on it. If it does, can you tell me the head stamps you see on the three bolts attaching the smog pulley. Sorry for the side question.
Sent you a PM.
Ok
Thanks. I have a very complete 72 smog pump system for a small block. I will be selling it. I just need a few thing for it.
If you can get pictures of it or any numbers off the hoses I would appreciate it. You could send pictures of (509) 953-8992 of tfringo@aol.com Thanks
dkleather (07-14-2016)
Sounds like the float sunk. A lot of the floats in the QJet are "polyfill" or "Nitrofill" and don't take well to the ethanol gas. I just rebuilt one for a friends 72 Buick GS 455 that the poly float sunk. Got a real brass float, carb rebuild kit with the blue or green ethanol accel pump that should take care of that problem for a long time.
Don
Don
Don
Don
After posting that I thought about it and decided with my luck I'd probably drop some small part down inside and have to remove it anyway. I'll take it off. Thanks.Dave
have you checked any of the ignition basics before removing the carburetor.
Have you checked the physical condition of the cap, rotor, and points?
Have you checked the plug wire resistance with an ohmmeter, 1k per foot of wire.
What spark plugs are installed, manufacturer and part#? Are they correctly gapped?
Did you check the point dwell?
Did you check the initial timing?
