I wasn't the one to reply to Kubs that was someone else. So let me ask you this. On the 17x9.5 with 4.5 BS would be different then the 15x8 with the 4.5 BS since it's 1.5" wider right? So I could just judge it based off that it will be not as far out basically 1.5"?
Im curious if I need to do a small spacer like your are running or if a 1" hubcentric adapter would be too wide.
My mistake. I was on my phone earlier. The only concern is the backspace as that will determine if you will make contact with the E-brake line. The additional width of the wheel (be it either a 9.5, 10 or 11 inch wheel will be out towards the fender. 9.5 inch minus 4.5 inch of B.S. just gives you 5 inches out towards the fender. You can probably do a 4.5 inch B.S. with like a 1/4 inch spacer and clear everything. But every car is different. I see people running 4.5 inch B.S. on a 15 inch wheel and clear everything. I could not do it on my car from some reason.
I gotcha. I guess I was trying to see if a 1" adapter would be too much as I think that's the smallest adapter they make. I was concerned with running a 1/4" or 1/2" bc I'd have to put longer studs. Anyone know if there are smaller adapters out there??
kubs, the 265's look wide on the 10's are they fitting about right or stretched or sneezed any?
I was gonna run 295's on the rear
Bats,
I would say they are slightly stretched if any, but the sidewalls are pretty even with the lip of the wheel.
They may look wider because putting a smaller tire on a wider wheel (to a small degree) helps bring the corners of the tread up and flattens the footprint. This also changes the angle of where the body plys go under the belt known as the "attack angle". This will help stiffen the sidewall and give better steering response, and the flatter footprint allows for more lateral traction.
So are you saying that you have the 275s on your stock wheels fitted to the car right now? If so, a 15x8 with 4.5" backspace and a 1/2" spacer will fit identically to your current wheels (you'll probably need longer studs and want nice spacers). As will a 15x8 with a 5.5" backspace and 1.5" bolt on spacers/adaptors - however keep in mind that these will also have less dish to the rim, which may or may not be the appearance you are looking for.
Yes sir. Have 275s on my stock wheels on the rear and 245s on the front. Guess I was hoping there would be a 1/2" adapter to run instead of spacers so I don't have to mess with longer studs. I guess I could check on 1" adapters but it will kick the wheel and tires out an extra 1/2" which may be too much.
That would put the wheel 0.5" closer inside the body than in the picture I posted. Its up to you if that still sticks out too much or not. Shouldn't have any clearance issues on the inside part of the wheel.
Hmm I may run that. I wonder if running a 1" adapter would be better as far as having the tire not as far out the body. Think I wouldn't have clearance issues in the back side?
At least on my car, the stock wheels with 4" of backspacing put the wheel really really close to the spring and parking brake cable. I don't think there was enough room to go farther in. However, places like Van Steel make shorter springs, and it would be real easy to move the parking brake cable bracket.
They make that wheel in a 15x10 with 5.5 backspace. If I ran a 1.5" adapter in the rear would I have any clearance issues?
The 275 tyre will be roughly an inch wider on the 10" wide wheels (rough rule of thumb is 0.5" extra section width for every extra 1" of wheel width). If you run a 15x10 with 5.5" backspace and 1" spacer (effectively 4.5" backspace), then the tyre will sit ~0.25" closer to the inside and ~0.75" closer to the outside. Remember these are all only rough approximations... But it should give you an idea of how likely it is to work. How much space do you have available?
Ill measure it tomorrow. But looks like the passenger rear tire is out farther then the driver's side. Def noticeable. Not sure why though. I will get some pics of it as well.
