Courtesy Lights
Old Jul 16, 2016 | 11:35 AM
melhard's Avatar
melhard
Default Courtesy Lights
Courtesy lights won't shut off after I close doors and moved light switch to normal position. I replaced all the door push in switches and still they stay on. Is there a light timmer keeps the lights on after the doors are closed not working and if so where is it? Thanks 76 corvette
Old Jul 16, 2016 | 11:57 AM
Alan 71's Avatar
Alan 71
Hi m,
Do the lights turn off when you push the switches in by hand?
I believe you'll find that turning the regular headlight pull **** turns the brightness of the interior and dash lamps up and down.
The rheostat is part of the switch.
Regards,
Alan
Old Jul 18, 2016 | 07:17 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by melhard
...Is there a light timmer keeps the lights on after the doors are closed...
Not stock for 76. It's possible a PO may have added one.
To Courtesy Lights
