Front wheel bearing
Old Jul 18, 2016 | 01:49 PM
The Punisher's Avatar
The Punisher
Default Front wheel bearing
I started getting a slight squeal from what I believe is the front wheel bearing. It stops when I apply the brake or turn the steering wheel. Is this a hard job to replace the bearings?
Old Jul 18, 2016 | 02:06 PM
gungatim's Avatar
gungatim
nope super simple. same as any other car up through the early 80's...
Old Jul 18, 2016 | 02:07 PM
GregS_72's Avatar
GregS_72
From: St Louis MO http://1972corvetterestomod.blogspot.com/
Not hard at all. See this...
http://www.corvettemagazine.com/tech...ng-replacement
Old Jul 18, 2016 | 05:20 PM
SIXFOOTER's Avatar
SIXFOOTER
Shoot me an email address and I'll get you a paper I did several years ago on the subject.
However, a slight squeel that goes away when brakes applied is usually brake pad wear. Bearings usually rumble
Old Jul 18, 2016 | 06:14 PM
fishslayer143's Avatar
fishslayer143
I agree , bearings don t usually squeal. They sound more like rolling marbles in your hand . In any case, pretty easy job if that's what it is. do inner and outer w/seal , don t half azz it
Old Jul 18, 2016 | 09:19 PM
The Punisher
Brake pads and rotors have less than 3000 miles. Ceramic pads and drilled and slotted rotors
Old Jul 18, 2016 | 09:23 PM
Giddy-up Go's Avatar
Giddy-up Go
An easy job - I could do it!
Old Jul 19, 2016 | 12:32 AM
7T1vette's Avatar
7T1vette
Are you sure your brake pads aren't just getting worn and the 'scraper' on them is just letting you know the pads need changing?
Old Jul 19, 2016 | 08:01 AM
The Punisher
less than 3000 miles on them
Old Jul 19, 2016 | 08:18 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I've heard that slotted rotors can make a "fan like" noise, as air is being passed through the slots on the rotors. Could it be that?
Old Jul 19, 2016 | 10:35 AM
The Punisher
I would think if that were the case that the sound would change at different speeds
Old Jul 19, 2016 | 03:18 PM
7T1vette's Avatar
7T1vette
How long has it been since you greased your wheel bearings?
Old Jul 19, 2016 | 03:52 PM
The Punisher
I have owned the car 5 years and have never done it
Old Jul 19, 2016 | 04:20 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Might be a good place to start. There is a really simple tool that I found years ago for repacking bearings. Replacing them isn't hard but I find the hardest part is to remove and replace the races. You won't need yo for this if only repacking. If the noise goes away for a while, you'll know that you're on the right track.
Old Jul 19, 2016 | 04:23 PM
CA-Legal-Vette
Here's the packing tool:
http://www.northerntool.com/shop/too...FVBffgodoe4FVA
Unbelievable how much mess it saves.
Old Jul 20, 2016 | 12:27 AM
7T1vette's Avatar
7T1vette
Or, you can do it the old-fashioned way: put a gob of grease in the palm of one hand and use the other to press the bearing/race down into the grease and force it down into the bearing. "Packing" the bearing with grease means that the entire bearing roller set and cage are COMPLETELY filled with grease.
Old Jul 20, 2016 | 09:36 AM
gungatim's Avatar
gungatim
that's the way I was taught and still do it. if you aren't getting dirty you aren't working hard enough...even those tools leaves voids and requires some hand work I have found...
races are not as hard as it used to be when nobody but the pro's had the right driver tools for them, but today for <$20 you can buy a high quality set from HF to properly install them. no excuse not to replace the races anymore, whether a 'vette or a boat trailer or whatever etc.
can't tell you how many times I see a box with and old bearing and the new never installed race still sitting in it at someone's yard sale...
To Front wheel bearing
