Hood Locked!
Old Jul 21, 2016 | 08:22 PM
Safeharbor's Avatar
Safeharbor
1st Gear
Default Hood Locked!
Hi Folks,
New member here! I bought a 73 a few months ago, and it has been a nice daily driver. Has a few small problems, but overall ok. I am working on a stalling/restarting issue, but that is for another day. Because now I can't get under the hood! I pull on the hood latch release and it just won't open. Need to get in there to do anything else. Please advise!
Thanks!-AJ
Old Jul 21, 2016 | 08:34 PM
Skip Burney's Avatar
Skip Burney
My 73 locked like that once and I think one side was released and the other wasn`t I was able to squeeze my hand in there and grab the cable and pull it. Now I have a small hole drilled so that I can slip a hooked piece of wire in there to pull it if it ever happens again
Old Jul 21, 2016 | 09:43 PM
jim in oregon's Avatar
jim in oregon
Originally Posted by Safeharbor
Hi Folks,
New member here! I bought a 73 a few months ago, and it has been a nice daily driver. AJ..I posted a fairly detailedHas a few small problems, but overall ok. I am working on a stalling/restarting issue, but that is for another day. Because now I can't get under the hood! I pull on the hood latch release and it just won't open. Need to get in there to do anything else. Please advise!
Thanks!-AJ
AJ, I posted on a thread a day or so about this issue..I assume you have had the hood open since you got the car..thake a look at this thread..Jim
https://www.corvetteforum.com/forums...e-problem.html
Old Jul 22, 2016 | 12:27 AM
tpfarm's Avatar
tpfarm
Many many threads on this subject, do a search and you will see.
BTW had the same problem on my '73 but only after I had made some adjustments and failed to make sure the latches were centered before closing the hood. Had to loosen the bolts at the front of the hood in the wheel well area and it popped free.
Good luck
To Hood Locked!
