Battery Replacement C3
Old Aug 3, 2016 | 03:20 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Originally Posted by LT1M21Vette
Anyone installed a smaller lighter battery, ie Odyssey or something similar?
Over the years I pretty much have put an increasingly lighter battery in my '69 every time it needed a replacement. The car is not a DD and does not sit outside on frigid winter nights. As long as it starts at 40* and above, I'm happy.
For the past 3 or 4 years I have had a 16# 365CA/300 CCA $29.95 (Interstate?) battery in my '69. (If and when this battery starts to get lazy, I'll throw it in my lawn tractor and spend another $29.95 for a new piece.) I like to track my car, and I don't like hauling around any more lead ballast than I absolutely have to.
Old Aug 3, 2016 | 04:38 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
the Walmart battery (Ever Start) actually has a provision for a vent tube,
it is not air tight, but they put some thought into . (next to Red sticker)
I also use the Walmart battery,just get the largest cold cranking amps you can fit.
get a free warranty battery virtually in any city, anywhere. with some open 24hrs.
hard to beat that.
Old Aug 3, 2016 | 07:11 PM
OldCarBum's Avatar
OldCarBum
I own a '73 Coupe. The prior owner, Bubba, replaced the original style top post battery for a side post battery and swapped the cable connectors. It is impossible to see or check the battery posts and connections in the battery compartment, and a royal pain to connect my trickle charger to the battery. I plan to go back to the original style top post battery and replace the cables. Don't let someone talk you into this modification.
