Side seat stud acorns?
Old 08-01-2016, 09:23 PM
alconk
alconk's Avatar
Default Side seat stud acorns?
What's the best way to keep the acorns on that holds the plastic trim on over the seat pivots? I bought a new set awhile back but keep finding them on the floor. It seems like after I pressed them on they were loose to begin with so I squeezed in rope butyl in the hole them pressed it back on. It seems to help but what would be a permanent solution?
Old 08-01-2016, 09:33 PM
Shark Racer
Support Corvetteforum!
Shark Racer's Avatar
I'm interested as well.
Old 08-02-2016, 06:21 PM
kaz1961
kaz1961's Avatar
I put a dab of black Permatex on each pin and stuck the acorn nut onto it. Havent had one fall off since doing this.
Old 08-02-2016, 07:42 PM
Shark Racer
Are you essentially siliconing them into place, or are you letting the RTV set up to take up some of the gap?
Old 08-02-2016, 08:32 PM
alconk
alconk's Avatar
Aww good idea! Will try that thanks!
Old 08-03-2016, 01:22 PM
M. Young
M. Young's Avatar
I put RTV inside of the nut before I pressed it on to the stud and haven't had one fall off either.
Old 08-04-2016, 07:08 PM
kaz1961
kaz1961's Avatar
I put them on with the rtv wet so the are stuck in place.
Old 08-06-2016, 07:06 AM
Richard Cooper
Richard Cooper's Avatar
Had the same problem on my 81. Every time I opened the drivers door there were acorns on the floor & under the seat. So, I removed the seat cushions and took out all the screws that have the acorns and then I threaded (10-24) the ends where the acorns go. I used nylocks and a pair of long nosed needle nose pliers to put the nylock on. I used chrome nylocks and it looks good.
Old 08-06-2016, 09:05 AM
gjohnson
gjohnson's Avatar
I got rid of those POS things. I replaced the the bolts and put real theaded acorns on.
To Side seat stud acorns?
Quick Reply: Side seat stud acorns?
