Window motor? 1980 C3
Old Aug 2, 2016 | 07:06 AM
BSeneca's Avatar
BSeneca
Default Window motor? 1980 C3
Hello guys. First I want to thank everyone that answered my questions and helped me in choosing my new to me 1980. I had a 1993 that I bought from a trade in at our dealership. Got into REALLY good, then everything went wrong. Blown engine, rebuild etc etc. It took a big loss in the end but got what I always wanted. Anyhow. The passenger window only goes up to an inch or so from being completely closed. Is this off track or should I replace the whole motor on both. How difficult is this to do. I am new to Corvettes so any help would again be appreciated. Thanks, Brian
Old Aug 2, 2016 | 12:04 PM
SwampeastMike's Avatar
SwampeastMike
If I had to guess there's a couple stripped teeth on the regulator gear arm. To test that theory have someone pull up on the window firmly as it is raised with the switch. If it goes up after a "skip" it's the regulator gear arm. If it won't raise any further then something is jammed.
An overlay repair piece is available that saves the rest of the regulator.
Replacing the motor and/or regulator and/or door glass and/or mechanism isn't too bad of a job. There are good instructions available here if you do some searching. Look for a photo here that shows the door with the window and mechanism installed but without the outer door skin. It is extremely helpful! The FSM is also a decent aid.
While "not too bad" of a job it's also not the sort of thing you want to do often Given this you should really plan on disassembling, cleaning and lubricating everything inside the door (replacing worn pieces as necessary) as it is likely in serious need of such.
Old Aug 2, 2016 | 03:07 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by BSeneca
...The passenger window only goes up to an inch or so from being completely closed. Is this off track...
Possibly not off track, but probably leaning in too much. If the door glass is leaning in too much, it begins to dig against the weatherstripping as it rises instead of sealing against it. If you can push the glass outward as it rises the last two inches or so and have the window roll all the way up, it's a sure sign it's leaning. Purchase the 1980 assembly instruction manual (AIM) and read the section on how to set door glasses. It tells you how to set the lean of the glass to seal against the weatherstripping. Setting glass is not particularly difficult, but it is piddly business. Expect to make one or two tries at it before you get it.
...should I replace the whole motor on both...
Why? You aren't having problems with the motors.
Old Aug 2, 2016 | 04:27 PM
M. Young's Avatar
M. Young
Default 1980 Windows
Brian,
The AIM is a must have for these cars, it's cheap and the info is invaluable.
I bought an '81 and the drivers window was slow and pretty much worked like crap. I messed around with moving the window forward, aft, up and down to try and "fix" the problem. But then I figured that these parts brand new were not the best quality and 30 years of neglect probably haven't helped either. So I tore it all out and got a new regulator, motor, new anti-rattle cushions and now its perfect Operates fast and smooth. You'll be kicking yourself when you try and "fix" the current components and get caught with your window down in the rain.
Old Aug 3, 2016 | 07:56 AM
BSeneca's Avatar
BSeneca
Thanks and no I am not, but I figured it may go as well being 36 years old. I REALLY love this car. I am 46 and this is what I think of when I think of Corvettes as a kid growing up (not that I knew anyone who owned one, just saw them on tv and things) so I am ready to put money into it. It needs little things like weatherstipping and so forth.
Old Aug 3, 2016 | 07:57 AM
BSeneca's Avatar
BSeneca
Originally Posted by M. Young
Brian,
Are the new parts readily available and where? Thank you so much for your help. I am new to corvettes and everyone here has been great. Thank you
Old Aug 3, 2016 | 09:03 AM
M. Young's Avatar
M. Young
Check out our sponsors like Corvette America. ext 253 talk to Danny.
A quick web search should bring up the biggest suppliers.
Buy these now...
http://www.ebay.com/itm/CORVETTE-198...pWdD3o&vxp=mtr
To Window motor? 1980 C3
