Windshield trim removal....
Old Aug 6, 2016 | 02:45 PM
Madhatr's Avatar
Madhatr
Default Windshield trim removal....
Hey everyone,
What is the best/most recommended way to remove the the stainless outer windshield trim from a 76 coupe? Any 'best practices' or experience to share? I am going to attempt to remove the windshield tomorrow and any advice would be greatly appreciated!
Old Aug 6, 2016 | 03:07 PM
Alan 71's Avatar
Alan 71
Hi M,
I start with the proper sequence….really the only sequence.
First the weatherstrip and it's retainers on both a-pillars.
Then the stainless steel reveal molding screwed to each a-pillar.
Next the long thin piece of stainless steel trim right across the top of the windshield header. (Here there are various methods employed… from using one of the 'trim tools', to gentle prying, in order to release the trim from the clips mounted to the header under the trim.)
Then the large piece running across the top of the windshield header.
Finally the chrome plated corner castings. You REALLY need to be careful here. Some of the screws that hold this piece in place are in a position that if you try to remove them with the windshield in place the glass can easily be damaged.
Are you replacing the existing glass or reusing it?
Good Luck!
Regards,
Alan
Old Aug 6, 2016 | 03:20 PM
SwampeastMike's Avatar
SwampeastMike
The trim on the sides is integral with the weatherstripping and its retainer. There are three screws. There are little access holes in the glass channel of the weatherstripping--one near the top, one middle and one bottom. Feel around with a #2 Phillips and you'll find the screw heads.
The top trim merely presses in place--pull straight out towards the front of the car.
If you're doing a thorough cleaning, etc. of the windshield area and decide to remove the cast corner pieces (the ones with the holes that position the t-tops) be careful. There are screws going into them from around the outside of the windshield. You'll be able to see them with the upper trim removed. DO NOT attempt to remove them with the glass installed as you will almost certainly make at least one tiny chip in the edge of the glass and it will eventually run. Also you MUST reinstall them BEFORE the windshield is replaced! I'm far from the only one who broke a windshield that way!
Also you'll find a black tar like compound used on the windshield side trim and the "roof" trim (the "T" shaped piece, the front piece and the corner pieces previously mentioned). While I was able to find the GM product used in the assembly manual it is no longer an active GM product that I couldn't find anything similar at good auto stores. Described as "gunnable, fibered, bituminous" I used fibered asphalt patch (in a standard sized caulk tube) from a hardware store.
Old Aug 6, 2016 | 08:46 PM
Madhatr's Avatar
Madhatr
Thankyou for the info Gentlemen!
Alan, as alwa6s thankyou for sharing your expansive knowledge, and to answer your question:
Yes, and no... I am going to attempt to pull the good windshield out of this tub
And use it to replace the cracked one in my 77. I was aware that the winshield was in te way of the cast blocks, but only from a post on this forum from a couple years back. However part of my plan involves using this tub to mock up the roll cage I want to build. So the T top blocks will stay for now to aid with proper clearance.
SwampeastMike: Good to know about the adhesive! Where I work uses something that sounds similar to reglue windows in the back of our chassis cabs... I will have to look into it. The actual window swap probably won't happen until next spring though.
Old Aug 6, 2016 | 09:21 PM
Giddy-up Go's Avatar
Giddy-up Go
Chris - remember, you can always use the torch if need be! LOL! take pics for me man!
Old Aug 6, 2016 | 09:38 PM
Madhatr's Avatar
Madhatr
Lol, my experience has been that a 'universal hot wrench' is less effective on glass I am hoping to get some pics and even video... so if I break it, this should be fun
To Windshield trim removal....
