1969 BB fan shroud
Old 08-15-2016, 07:42 PM
mrh747
mrh747's Avatar
Default 1969 BB fan shroud
Needing to replace fan shroud.
Any one that can shed light on quality, originally, compared to the real original.
Are they all made by the same company?.
Max
Old 08-16-2016, 09:41 AM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The answer to this is complicated...
If you have the plastic shroud, I'd try to find an original. The reproduction of this shroud is too flexible and not as rigid as the original shrouds. When installed they tend to want to hit the fan blades. We've installed them and every time we have to make a stronger bracket for top to keep the shroud out of the blades.
For cars with the fiberglass shroud is a different story if it's the press molded version (and not the hand laid). It is a good reproduction but the supplier makes them to order which can take up to 8 weeks to get.
Willcox
Old 08-16-2016, 12:20 PM
mrh747
mrh747's Avatar
Default 1969 corvette BB fan shroud
Willcox
Thanks for your response.
The shroud I have is very sturdy, Gray in color with the grain streaks in it.
Based on the apprearance and physical characteristics, it is an original.
Sounds like I may be better to place a few stripes on the areas that are broken.
I did see that canes have a reproduction to match the original. What can you shed on that? Is that your supplier?
Thank you very much
Max
Old 08-16-2016, 12:49 PM
xpoc454
xpoc454's Avatar
I have the same setup with AC. What made the difference in if you got a big block plastic or fiberglass fan shroud? Mine had a big chunk taken out of the top portion of it. It is a clean break so I assume, but maybe wrongly, its plastic? My is a march 15th 69 car.
thanks
mrh747
mrh747's Avatar
Default 1969 Corvette fan shroud
Is that classified as fiberglass?
Thank you very much
I see prices from $299 to $450, even $more for an original, original.
Max
These are my latest findings
Old 08-16-2016, 01:00 PM
mrh747
mrh747's Avatar
thanks
Likewise my is a March 69
The shroud is ridged grayish in color.
Did you repair yous or replace it. Where did you buy it, if you replaced it?
I see med America has a fiberglass one listed,bat $429.
Max
Old 08-16-2016, 01:02 PM
xpoc454
xpoc454's Avatar
Max
I havent got mine fixed yet, I am in same boat as you. I will look tonight to find a number on it and look at it more closely. If yours has AC we may have similar one, Ive noticed the ac seems to make everything more unique and difficult.
jim
Old 08-16-2016, 01:11 PM
mrh747
mrh747's Avatar
Max
Keeping it all original, or at least quality reproduction components.
Mine is not A/C.
Am experiencing it over heating.
Just pulled radiator, having it boiled, fins combed, tested, painted.
Will be installing all new radiator/shroud insulation.
Thanks for you input.
Max
Old 08-16-2016, 01:13 PM
0Willcox Corvette
Former Vendor
Thank you very much
Max
Yes that would be the same supplier. The fiberglass shroud is very thin, probably 1/8" thick, the plastic shroud is thick around 3/8".
https://willcoxcorvette.com/catalogs...c_part_year=19
Old 08-16-2016, 01:37 PM
USAFVeteran
USAFVeteran's Avatar
I'm using a Mark VIII fan on my 69 BB and don't need my original shroud, and I think it's in good shape. PM me if you're interested, and I'll take some pics of it.
mrh747 (08-22-2016)
Old 08-16-2016, 04:35 PM
xpoc454
xpoc454's Avatar
Found my mumbers on my fan shroud. Mine appears to be blackish. I also have a picture of the missing chunk from the top of it. Does the numbers indicate plastic or fiberglass?
Done this from my phone.
Jim
Old 08-16-2016, 04:53 PM
USAFVeteran
I Googled that number and got a ton of big block shrouds. I think I'll sell mine now, had no idea they were going for that much.
Old 08-18-2016, 11:25 AM
0Willcox Corvette
Former Vendor
3956119 is the plastic shroud for sure.
There is (or was, I'm not sure if they are still making it) a fiberglass reproduction version of that shroud that would be a better shroud than the junk reproduction plastic version. This the reason the originals are bring so much money for originals.
Willcox
Old 08-22-2016, 11:33 AM
mrh747
mrh747's Avatar
Default 69 vette 3956119 fan shroud
If your fan shroud in in excellent condition and not been repaired, I am interested in it.
Please send pic an asking price.
Mrh747@yahoo.com
Thanks for your posting.
Max
Old 08-25-2016, 07:20 PM
mrh747
mrh747's Avatar
Default 3956119 BB 69 Vette fan shroud
I am very interested in your fan shroud.
You mentioned it is in excellent condition.
What are you asking for it?
Please send pic.
Mrh747@yahoo.com
Thanks for your time.
Max
Old 08-26-2016, 12:36 AM
USAFVeteran
Please send pic.
Mrh747@yahoo.com
Max
PM sent, sorry for the delay, been working on mine.....
To 1969 BB fan shroud
Quick Reply: 1969 BB fan shroud
