Aftermarket steros
Old Aug 16, 2016 | 01:54 PM
MattsC3's Avatar
MattsC3
Default Aftermarket steros
I was wondering what was a good aftermarket stereo to replace the factory stereo in my 82. I am especially interested in something with Bluetooth or aux. I don't feel Like spending a small fortune, maybe a couple bills. Also how much of a pain is it to replace the speakers?
Old Aug 16, 2016 | 03:22 PM
SwampeastMike's Avatar
SwampeastMike
Do you have an original two-shaft radio now? If so be aware that there are very few new options if you want to keep that mounting. Otherwise you either cut up your existing panel to allow a DIN sized unit or get a new panel with a proper DIN opening.
It is possible, I believe, to replace the dash speakers without removing the dash. I replaced mine when I had the dash out for other work and it was easy. There is also a large selection of available speakers that fit perfectly.
The mounting bracket for the rear speakers [seems] to only work with the OEM units. The magnets on most 6x9 speakers are far too large in diameter to work with the factory mounting brackets. If someone makes an alternate bracket to work with typical 6x9s I am unaware of such. For a good job you either make (or buy) speaker enclosures or fabricate a mounting bracket.
Old Aug 16, 2016 | 06:53 PM
rmm82's Avatar
rmm82
I just completed this effort in my 82. I went with RetroSound Model 2 Stereo ($329), RetroSound S-692 6x9 rear speakers($69), Kenwood KFC-4675-C 4x6 front speakers ($45). Installation of the front speaker was relatively easy. Installation of the rear speakers were somewhat a pain, only because I tried to install Kenwood 6x9's that were supposed to fit but didn't. The stereo itself wasn't difficult, but it took a bit of time to adjust the shafts and ***** to get the correct fit. Do take out the cluster gauge and adjust the stereo to it on a table first before trying to install it in the car. The stereo sounds much better than the old one, but it's not a Bose or JBL system you'd find in todays high end vehicles. With that said, I do like the new Bluetooth technology. Do order the wiring kit from Crutchfield (Metra 70-1677-1 and Metra 72-4500), makes it a lot easier.
Old Aug 16, 2016 | 08:57 PM
terry82's Avatar
terry82
https://1982corvette.shutterfly.com/pictures/365#365 I looked into buying a stereo head unit that I would not have to cut the dash.It was expensive and it they may not have been that great . Some are better now.for my car it will never be in a museum so I cut the dash .It gives you lots of choices.The speakers are easy to replace in the front .the covers come right off ,but you can not put a speaker in there with much of a magnet theres no room .put them in the kick panel .polk has a speaker that works great .The rear speakers you can put in 6x9 but you have to work at it .you also could put in a box that will house the amp and the speakers .do a search and you will find lots on this topic
Old Aug 17, 2016 | 01:53 PM
Richard Daugird's Avatar
Richard Daugird
I got an Alpine CDE-SXM145BT with Sirrius XM replay feature. If you have satellite radio subscription, this is nice because you can rewind, and then fast forward the songs that play. it was less than $150 I believe. CD, AUX, Bluetooth, etc., and lots of stuff I don't know how to use! Will recognize iPhone/iPod as well. It is not installed yet, but I have the same unit in my Ranger, and will be getting one for my '65 Buick as well. I really like it.
Old Aug 18, 2016 | 02:01 AM
radiofixer's Avatar
radiofixer
1st Gear
You can go with Custom Auto Sound
http://www.casmfg.com/Corvette%201977-82%20USA-630.htm
To Aftermarket steros
