82' O2 sensor
Old Aug 21, 2016 | 01:10 AM
antoniov1's Avatar
antoniov1
Default 82' O2 sensor
I'm about to buy a O2 sensor for my vette I took the smog off and need a hot sensor i guess? What kind do y'all recommend? And please include a link.
Old Aug 21, 2016 | 08:41 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
There is nothing magical about an 82 O2 sensor. Just pick one up at Autozone or O'Reillys.
You will still need one as it will throw a code.
Old Aug 21, 2016 | 06:42 PM
DUB's Avatar
DUB
When a Corvette has had the catalytic's removed....YES...I have used the three wire heated O2 sensors for a Corvette and ran a FUSED 12 volt source, a ground and then connected the last wire to the current wire so it will heat up and not rely on exhaust to do it.
I believe the O2 sensor was for a 1992 ZR-1 if my memory serves me correctly.
DUB
Old Aug 21, 2016 | 10:51 PM
terry82's Avatar
terry82
bosch has several choices.
Old Aug 22, 2016 | 06:25 PM
DUB's Avatar
DUB
That is who makes them for GM....so I have been told by customer who works for BOSCH.
DUB
Old Aug 27, 2016 | 04:34 PM
antoniov1's Avatar
antoniov1
Can you suggest a link I can find one at for some reason I'm having a hard time finding it..
Old Aug 27, 2016 | 05:32 PM
DUB's Avatar
DUB
????.... GOOGLE ......"1992 Corvette ZR-1 OXYGEN SENSOR"
read post # 3 again....
DUB
Old Aug 27, 2016 | 05:33 PM
antoniov1's Avatar
antoniov1
But that would work on my 82'?
Old Aug 27, 2016 | 05:47 PM
DUB's Avatar
DUB
Did you read my post #3????
I wrote that I have USED this type of O2 sensor....SO ...YES...it will work but you have to wire it in. Because your O2 sensor is only a ONE WIRE sensor...and the heated O2 is a three wire.
DUB
Old Aug 28, 2016 | 02:21 PM
antoniov1's Avatar
antoniov1
Do you think this would work?
Old Aug 28, 2016 | 05:45 PM
DUB's Avatar
DUB
That should work just fine if you choose to use it.
DUB
To 82' O2 sensor
