"Bubba" Strikes Again!
Old Aug 25, 2016 | 09:28 AM
Ben N's Avatar
Ben N
Default "Bubba" Strikes Again!
Admin, please move this to "General" for me. I tried to move/delete it, to no avail. Thank You.
OK, my ongoing "De-Bubba-Izing" continues!
Well, MAYBE this one is NOT caused by "Bubba"...
Took the '69 out for a cruise last evening.
Doors are tightly shut.
Turned on the headlights while on the way home and the "Door Ajar" light turns on, along with the headlights.
Turn the headlights off, and the "Door Ajar" light shuts off too.
Gee, THANKS "BUBBA"! Then again, maybe this one is NOT "Bubbas" doing. LOL...
Crossed wires?
Dead short somewhere?
Bad door-ajar sensor/switch?
Any ideas?
Thanks Again,
Ben N
Old Aug 25, 2016 | 09:57 AM
Ben N's Avatar
Ben N
Admin, please see my note at the top of the above post.
Thx,
Ben N
Old Aug 25, 2016 | 01:39 PM
Priya's Avatar
Priya
Click on the "report post" icon in the lower left to get the attention of the admins. Otherwise they won't see your request until when or if they happen to come across this thread on their own.
Old Aug 25, 2016 | 07:09 PM
Ben N's Avatar
Ben N
Thanks Priya.
DONE! LOL...
Old Aug 25, 2016 | 08:28 PM
vettebuyer6369's Avatar
vettebuyer6369
Ben, the best way to get something done like this is to check the list of moderators for the section you are posting in (usually found at the bottom of the General page) and drop a mod a PM directly for assistance.
Reporting a post will work too, but depending on individual software, a PM is more efficient.
I'll move your post.
Old Aug 25, 2016 | 08:51 PM
kdf1986's Avatar
kdf1986
I would go with the crossed wires. For the door ajar switch to come on when the headlights are up, that has to be two separate circuits wired together. The door ajar light should get its signals from the two door jamb switches. Somehow it is tied into your headlights opening.
kdf
Old Aug 26, 2016 | 11:23 AM
chstitans42's Avatar
chstitans42
TheCorvetteBen
ten bucks you have the "door ajar" socket swapped out with the "headlamps" socket. These are right below one another in the cluster, and can easily be switched on accident.
Old Aug 28, 2016 | 11:22 AM
Ben N's Avatar
Ben N
Thanks All!
I'm leaning towards something other than swapped lights, because the door ajar idiot light goes on even with the headlights in the "Off" position.
Old Aug 28, 2016 | 02:32 PM
Alan 71's Avatar
Alan 71
Hi Ben,
Have you checked the operation of the door switches with the doors open by pushing on the switches individually?
If they work properly then you may need to adjust the switch (move it out) so the door pushes the switch far enough to shut the lights off.
The pad on the rear of the door had a small square rubber bumper on it that insured that the door pushed the plunger on the switch in far enough.
Check to see that those pads are there.
Regards,
Alan
Old Aug 28, 2016 | 04:42 PM
jnb5101's Avatar
jnb5101
If the "door ajar" and "headlight" sockets were switched, it wouldn't explain why the "door" light came on with the headlights. The "headlights" (in your case the "door ajar") bulb should only illuminate when the headlight mechanism doesn't fully open. The headlight circuit may be searching for a path to ground thru the "door ajar" bulb. If you had the dash apart and reversed the two sockets and one of the headlight position sensing switches is malfunctioning, the "door ajar" bulb would illuminate.
To "Bubba" Strikes Again!
