Cost for interior restoration
Old Sep 1, 2016 | 05:53 PM
ballen06's Avatar
ballen06
Default Cost for interior restoration
1969 corvette L46
I am planning on taking my corvette into a shop and having some interior work done. I need the following done:
1)install upper dash
2)install LH dash panel
3)install RH dash panel
3)install center cluster/bezel
4)install consoles and shift plate
5)insulation and carpet
All parts need to be purchased with the exception of the console and shift plate.
Can someone give me an rough idea of the cost for having this done.
I probably would take the car to a shop with experience with this work.
Thanks for your input.
Old Sep 1, 2016 | 06:00 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Just a rookie guess: Parts--Medium grade (not restoration nor show quality) $1500
Labor $1200+
(I'm forcing myself to do all the labor so I can spend the "saved money" on a quality paint job)
Old Sep 1, 2016 | 07:07 PM
DUB's Avatar
DUB
Hopefully the shop you take it to KNOWS what they are in for.
There is a lot more than JUST installing these parts ONCE you get the old ones out.
Like I tell my customers....when I have it all out.....IF your lenses for your speedo and tach and center gauges are scratched up and dull. it is insane to have me put these back onto the new parts that look good...because you WILL regret it.
And then there are the light bulbs..... put new ones in it and MAKE SURE that the housing on the light bulbs are the brass design so they stay caged in the socket. A lot of the silver housing design light bulbs will pop out due to the side pins are not well defined and will not hold.
Making sure that all air ducts are cleaned and sealed up and that is if it is an A/C car or not.
Possible damage to the already worn steering coupling can also occur due to the steering column needs to be dropped so the speedo/tach cluster can come out with out busting things.
They also do not install the three rubber plugs in the rear vertical wall of the car also....they just glue the heck out of it.
Replacing the rubber carpet plugs and ACTUALLY taking the time to install them. Many places don't do this due to the hard plastic pieces that go under and around the base of your steering column can be a bit of fun and a hassle and most people are not aware of them.
AND..this happens quite a lot when I get Corvettes in my shop that someone else put together. They do not install the two 10-24 nuts that hold the center gauge bezel to the console....and many items they do not have the park brake console correct and the shifter console correct....it is all 'screwed-up'... and many times....if I am lucky... they put any of the screws in there correct locations correctly.
And OH yes...if that is not enough...when it comes to the rear storage compartment frame and lids...that is also a FUN area to get right and not all screwed up.
DUB
Old Sep 1, 2016 | 08:29 PM
terry82's Avatar
terry82
If I was doing all that dash work, I would replace the heater core.
Old Sep 1, 2016 | 09:55 PM
Richard454's Avatar
Richard454
DUB
OH- and if the gauges/needles are faded...firewall insulation... Speedo - tach cables-vacuum lines need to be checked/replaced...speakers probably need to be replaced(70 later in the dash)...
Old Sep 2, 2016 | 01:18 AM
Tim 1973's Avatar
Tim 1973
The prices you can get from any of the corvette suppliers but would watch for free shipping. It will be more the 1500.00 you might want to add new mounting screws lenes and if you have it all apart insulation like Richard mentioned. Lots of parts that you did not mentioned that once its all apart you might look at and want to replace them also. One thing will lead to another.
Good luck
Tim
Old Sep 2, 2016 | 06:03 AM
billcarson's Avatar
billcarson
if after what you just read from the faithful you decide to do this yourself join a gym first to improve your flexibility,you'll need it.
Old Sep 2, 2016 | 06:59 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
As far as labor for the installation is concerned, get an estimate from the shop.
Old Sep 2, 2016 | 08:48 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
My carpet, padding and insulation alone came to $600.00. Its all pretty easy installation if you have the time to do it yourself. Especially with the seats out and the steering column dropped. You wont need to be a yoga master.
You learn alot about whats where as well. The only hard part is putting the wiring harness behind the dash. Just take a pic as you pull it off. If you're in the northeast I would add another grand to that price easily.
And while your in there.....check out your wiring harness, dash bulbs, switches, etc. May as well only get in there once.
Make sure they triple check the oil pressure lines prior to restarting after the restoration. It can get ugly fast
Old Sep 2, 2016 | 08:59 AM
ballen06's Avatar
ballen06
Labor $1200+
That was my plan until I started to put the dash pieces back in..above my skill level at this point in my life.
Old Sep 2, 2016 | 09:01 AM
ballen06's Avatar
ballen06
DUB
DUB... I hear you ... probably should add a 25% contingency for issues unknown until you get into it.
Thanks for taking the time to reply.
Old Sep 2, 2016 | 10:38 AM
joewill's Avatar
joewill
heater controls? vacuum lines, vacuum, radio restore, replace wiring harness, shifter boots..
as you see, I would add a lot to the base cost,, things will break and will be rusted away, or screws stripped when you get it all apart. You really don't have to do it all, but as stated, a rusty part with lots of patina next to a new part is discouraging.
Old Sep 2, 2016 | 01:20 PM
VETFEVER's Avatar
VETFEVER
Remove the seats if you're doing dashboard and console work. 4 bolts each and you\ll have so much more room to work as well as lie on your back to access things..
Ask me how I know...
Old Apr 17, 2021 | 09:09 AM
oem427's Avatar
oem427
6th Gear
DUB
Hi DUB My name is mike b from Pa I have a 1969 that i want all new full interior complete. Black Leather and want the best including all gauges all new hardware. I am from northeast Pa. and willing to bring the car to you! I am looking for a top flight job ! even though i'm going to drive this car Not just park it and go to shows. I know there is a lot of variables involved so you can assist me with advice on the wright companies you like for all of the components ! I am doing a frame off complete nut and bolt restoration! F41,j56,m22,4.10:1,Ti ignition, My Phone # is Home 570-299-5495 Thank You "DUB"
Old Apr 17, 2021 | 09:28 AM
Shovels and Vettes's Avatar
Shovels and Vettes
Default Old
You do realize this thread is from 2016?? And Dub has not posted here for quite some time. You might try PM him, or getting his phone number; however, easier said than done. I believe his is down in Georgia or NC,.....maybe someone knows his contact information and will chime in.
To Cost for interior restoration
