right side mirror
Old Sep 4, 2016 | 12:41 PM
377's Avatar
377
Default right side mirror
how hard is it to install a right side mirror on a 73? the door is not drilled thanks
Old Sep 4, 2016 | 12:49 PM
John 65's Avatar
John 65
I did this for a friend of mine last year on his 74.
Its easy. The mirror should come with a template to show
you where to drill the holes in the fiberglass. Once drilled, we popped in the 2 rubber well nuts that came with it and then screwed the metal mirror mount to them.
Go easy with the drill, don't let it "walk" up the door.
Good luck.
Old Sep 4, 2016 | 12:52 PM
USAFVeteran's Avatar
USAFVeteran
Don't forget to measure the drivers door to get them symmetrical, both fore and aft, and elevation measurements
Old Sep 4, 2016 | 01:20 PM
Paul L's Avatar
Paul L
Good luck.
With the template it is pretty simple.
Old Sep 4, 2016 | 01:34 PM
377's Avatar
377
were did u get the mirror kit from thanks
Old Sep 4, 2016 | 01:37 PM
ddawson's Avatar
ddawson
Place some painter tape under the template. Drill a very small pilot hole to reduce the bit walk.
Measure the drivers said like said for a better match. Pretty easy.
Old Sep 5, 2016 | 07:05 AM
Blue73Shark's Avatar
Blue73Shark
Here is a picture of the right side mirror I installed on my 73 last summer. Follow all the advice given in the previous posts and it will come out nice. I suggest measuring the location of the left side mirror and compare it to what the right side template indicates. You might want to adjust it slightly so both mirrors look to be in the same position relative to the window, when viewed from the front/back of the car.
I bought the made in USA mirror (not date coded) from Willcox. I am very happy with it.
Fran
Old Sep 5, 2016 | 11:10 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
make sure you have the special (rubber well) attaching nuts, before you get started.
Old Sep 5, 2016 | 11:17 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
If you follow the advice given so far, on a scale of 1-10, 1 being easiest, it's a 1.
Old Sep 5, 2016 | 01:41 PM
377's Avatar
377
thanks for the info
To right side mirror
