BB Powermaster starter wiring?
Old Sep 11, 2016 | 11:44 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Originally Posted by Peterbuilt
Mini starters draw less current so the R terminal was eliminated.
That makes sense. Easy enough to test too since it won't start if it does need the additional voltage.
Old Sep 17, 2016 | 05:55 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Got it all wired up as suggested above, yellow wire taped off. I was able to get all those wires attached to the IGN terminal. Taped off the yellow wire. Also added a new block to frame ground strap and assure metal to metal contact.
It cranks real strong when cold. Warmed it up and when hot it sort of pauses for a second and then the starter cranks. You can sort of hear it struggle for a second or so.
Not sure what that is.
