1969 Corvette stingray six pack
Old Sep 20, 2016 | 11:54 AM
Naterobbins139@gmail's Avatar
1st Gear
Default 1969 Corvette stingray six pack
Hey guys I got a 1969 corvette stingray. Car says it's a 427 400hp but the carb has been switched before I bought it. Is there a definite way I can check to know if the car originally came with a six pack or not. I've pulled numbers off the car and Google as much as I could but I've gotten alot of different answers. Any help or advice would be much appreciated.
Old Sep 20, 2016 | 12:06 PM
BBCorv70's Avatar
BBCorv70
Only way to know for sure is if you have documentation, the tank sheet, invoice, maybe the Protect-O-Plate. Another possibility could be the build code on the engine block, not sure how much info that provide. Assuming it's the original block.
Old Sep 20, 2016 | 01:08 PM
steffan's Avatar
steffan
see if you have a return fuel line on the passenger side frame. I am fairly certain tri powers did not come with this.
Old Sep 20, 2016 | 02:21 PM
Lindstrom's Avatar
Lindstrom
Hello Nate,
What specific "numbers" did you pull? ...
If you believe a picture is worth a thousand words ...
Pictures of ...
1. Tachometer
2. VIN plate(located driver side windshield)
3. engine pad(located passenger side front where head & block meet.
4. engine bay - from driver & passenger side
5. fuel lines(from fuel pump or behind rear passenger tire)
6. console plate
Old Sep 20, 2016 | 02:27 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Lindstrom
...2. VIN plate(located driver side windshield)...6. console plate...
Nice to know, but not necessary. There is no option information in the 69 VIN. The console plate is probably the last item to attempt to use for verification. The plates are too easy to change.
Old Sep 20, 2016 | 02:38 PM
Alan 71's Avatar
Alan 71
Hi Nate,
WELCOME!
First Post!!!!
69, 427 car! NICE!!!!
Probably the best clue you could uncover would be L's #3, in his list above.
You'll be looking for a suffix code of LQ (400 hp ,4-speed) or LN (400hp, turbo hyda-matic). Both engines had tri-power. (When I see 'six-pack' the only thing that comes to mind is mopar.)
Hopefully the pad and it's stamps are still in good condition!
Regards,
Alan
Here's a typical pad with the head removed. LR indicates a 435hp, 4-speed car.
Old Sep 20, 2016 | 02:41 PM
Lindstrom's Avatar
Lindstrom
And you're 100% correct. The VIN plate will only determine if the block may be original to the car, assuming there may be numbers on the pad. And I agree, while the console plate is easy to change, I've seen some pretty obvious changed plates. In all, the more pictures, the better to ascertain. Put another way ... more pictures don't hurt, especially when you're given very little to begin ...
Old Jul 5, 2019 | 09:45 PM
Chrisjayne's Avatar
Chrisjayne
Default 427/400
Does anyone have a pic or a link to one showing the proper accelerator spring set up on a 69 427 400 tripower?
Old Jul 5, 2019 | 11:08 PM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
Here is a picture thanks to member 3x2 and here is a picture of the bracket that goes on the rear carb
Old Jul 5, 2019 | 11:10 PM
vettebuyer6369's Avatar
vettebuyer6369
You are posting to a three year old thread that has nothing to do with your question.
Please start a new thread asking your question.
To 1969 Corvette stingray six pack
