Roters and pads
Old Nov 8, 2016 | 11:07 AM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
I need to replace the front rotors on the Corvette. You can clearly side one side is thicker than the other and they didn't wear evening.
My question is which do I buy? RockAuto has several brands and I am not sure which one to get. I don't want slotted, but I don't want to buy a cheap brand either.
Here is my search:
http://www.rockauto.com/en/catalog/c...hub,rotor,1896
Thank you.
Old Nov 8, 2016 | 12:03 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Here is my search:
Thank you.
I would get the Centric premium rotors they are pretty decent.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Nov 8, 2016 | 02:08 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
you can buy on line at half the cost.
I have used "Brakemotive" products in the past, about 3 years ago
I installed on my suburban rotors slotted and vented your choice, and pads.
great product no complaints, no problems. cheaper than a brake job.
Old Nov 8, 2016 | 03:10 PM
RUU's Avatar
RUU
Old Nov 8, 2016 | 05:10 PM
Carbotech Adam
Supporting Vendor
Originally Posted by RUU
along with the Carbotech 1521 pads for street use your braking will be up to date..
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
Old Nov 10, 2016 | 07:38 AM
~Stingray's Avatar
~Stingray
Does anyone know the brands BrakeBest, EBC, Carquest Wearever?
RockAuto is charging $15 for shipping, so they are only 3-5 cheaper. These are the brands of my local stores.
Thanks.
Old Nov 10, 2016 | 07:40 AM
~Stingray's Avatar
~Stingray
Why do you think feel these are better than the Centric C-tek standard?
Or the ACDELCO ? The Dura International are marked as the favorites on the site.
Just trying to educate myself.
Old Nov 10, 2016 | 12:27 PM
lvmyvt76's Avatar
lvmyvt76
why do you need new rotors??? grooved or something??/ don't forget to check for runout on them.
Old Nov 10, 2016 | 12:33 PM
~Stingray's Avatar
~Stingray
The two plates are different thicknesses and they wore uneven from teh bad calipers.
Plus the cost to have them turned, if possible, is not far off than buying new ones. So why not?
Runout can be an issue on new rotors?
