Roters and pads
Old Oct 8, 2016 | 07:05 AM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Default Roters and pads
Hey Guys,
Couple of quick questions.
Can the rotors and pads for 1980 be picked up at the local hardware store? I don't need performance parts as I am just driving around for fun. Trying to save some money here as most kits for rotors and pads are over $200.
What is the difference between organic pads and hawk pads?
Thanks.
Old Oct 8, 2016 | 08:13 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Hardware store. No. Automotive parts outlet. Possibly yes.
Old Oct 8, 2016 | 09:32 AM
Jeffs82c3's Avatar
Jeffs82c3
Check out RockAuto.com
Old Oct 8, 2016 | 09:59 AM
kingkohlmn's Avatar
kingkohlmn
Veteran: Marine Corps
Got my pads and rotors at Autozone. Pick up the phone or go online and check the auto parts store for who has what.
Old Oct 8, 2016 | 10:46 AM
20mercury's Avatar
20mercury
Default Agree!!!
Agree!!!
For a Sunday driver, I buy AutoZone "equal to OEM" pads, rotors, and rebuilt calipers with a life time warranty, cheap and utilitarian
Old Oct 8, 2016 | 11:50 AM
bj1k's Avatar
bj1k
I bought rear rotors for my 2002 Silverado from AutoZone and two years later right after the warranty ran out ( two year warranty ) they rusted and separated so bad that it was ruining brake pads. I went to O'Reilly's and bought two new rotors with a LIFETIME warranty. They are the only auto parts store that offers a lifetime warranty on rotors and you can clearly see the difference in quality. We are finally getting some O'Reilly stores in our area and they will be getting my business.
Old Oct 8, 2016 | 12:26 PM
~Stingray's Avatar
~Stingray
Originally Posted by 20mercury
Agree!!!
Calipers too? I was about to buy a kit from one of our vendors. You actually suggest getting those from an AutoZone or Advanced?
Old Oct 8, 2016 | 02:37 PM
Cool95vette's Avatar
Cool95vette
Bought my pads and rotors from NAPA. I've bought calipers from them also. I'm happy with their products.
Old Oct 8, 2016 | 02:55 PM
rcread's Avatar
rcread
Are you sure you need rotors? OEM C3 rotors tend to last hundreds of years.
Old Oct 8, 2016 | 03:28 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Also, original rotors are riveted to the hub. If they need any machining, it can be performed using a frame-mounted tool to turn them.
Old Oct 8, 2016 | 04:05 PM
RMVette's Avatar
RMVette
I'd first check to see if your original rotors could be turned. I had all four of mine turned for $40 at a local shop. Had to drill the front rotor rivets out of mine but that job was easier than I thought it would be. Pads from any major parts vendor should be fine however I bought my pads online from Zip Products and my calipers from Vettco ($395 for all 4).
Old Oct 9, 2016 | 12:21 AM
20mercury's Avatar
20mercury
Default yep!
Yep, I have bought 3 caliper sets from Autozone and all 3 on 3 different C3's worked great. ditto a friend of mine too who originally suggested Autozone. I am sure Oreilly is good too and might be the same supplier too? ha! So I have had good luck going with them. Hope you have the same luck if you decide to go this route.
Old Oct 9, 2016 | 07:10 AM
Sluefoot's Avatar
Sluefoot
I got ALL my brake components (except emerg. brake parts) from AZ....good parts!
Have you double-checked to make sure your calipers are not leaking??
This'd be the bestest time to do all that.....cuz it'd be a pain to go back later & tear it all apart just to change the calipers, bleed the brakes, & assemble AGAIN!!
Old Oct 10, 2016 | 12:16 AM
terry82's Avatar
terry82
autozone,, brake master cylinder and calibers 20 years ago.i have used there lifetime warrenty a couple of times.They have the info on the computer .if they don't have the parts in stock they can have by the next day ,no shipping charges.the calibers look the same as what I took off.
Old Oct 10, 2016 | 02:15 PM
~Stingray's Avatar
~Stingray
They are leaking. I am getting advice in another thread.
https://www.corvetteforum.com/forums...post1593225815
Old Oct 10, 2016 | 02:17 PM
~Stingray's Avatar
~Stingray
lol, 100s?
I had a mechanic friend out to take a look at them. He said that when you get brake fluid all over rotors is happening (calipers need replaced), they typically need to replace the pads and rotors. I really didn't understand why. I thought you just just wipe it off. But he was pretty confident about it. Should I be second guessing that? If anyone is in the Indianapolis area and wants to come check out my situation, please offer. I will buy you meal/drink.
Old Oct 10, 2016 | 03:15 PM
20mercury's Avatar
20mercury
Default interesting
lol, 100s?
Interesting, I can understand brake fluid on the pads but the rotors too? I thought that was what brake cleaning fluid was for? assuming rotors are not scored too bad and minimum thickness. Time for a second opinion, IMHO.
Good luck to you
To Roters and pads
Old Oct 10, 2016 | 03:22 PM
Easy Mike's Avatar
Easy Mike
...Time for a second opinion, IMHO...
I agree. Fluid on pads, replace pads. Fluid on rotors, clean the rotors.
Old Oct 10, 2016 | 05:25 PM
terry82's Avatar
terry82
the money you save on rotors ,I would get new rubber lines.That way your brakes are done .
Old Oct 11, 2016 | 03:59 AM
marshal135's Avatar
marshal135
As stated rotors should be turned.
I was going to replace my original blued 68 rotors.
My mechanic friend almost back handed me.
He turned them and they stop great.
He said never trade good US steel for Chinese crap.
A good quality pad can be had from Delco or Rock Auto etc...
Marshal
