Fuel Pump Help!
After removing the old fuel pump, I removed the rod and applied some grease to help keep it in the up position to install the new fuel pump. Just to be sure it stayed up, I used a bent hacksaw blade to push against the rod, then positioned the fuel pump in place.
If you do a search, you'll find good information on the forum.
Good luck.
As for the pump push rod; On the front of the engine block, where the fuel pump bolts up, you will see a bolt installed in the block and a hole below that bolt. That top bolt, when removed and replaced by a longer bolt, will hold the fuel pump push rod in place. When you are ready to install the pump, push the rod up in the block, then lightly thread the holding bolt until it contacts the push rod and holds it in place. It should be pretty easy to install the pump. Once the pump is tightened, remove the holding bolt and re-install the original bolt.
Removing the hose and the steel line are self-evident. Screw driver or pliers to remove the clamp on the rubber hose, and a line wrench to remove the steel line. As to the other issues, fuel will dribble out of the supply hose. All you have to do is to clamp the hose. There are some neat plastic pliers made for this task, but you can also do it with some locking pliers. Just don't go tighter than it needs to be to stop the fuel leak. Clamp the hose before removing it from the pump and keep it clamped until it is ready to go back on the pump. You have to connect the pressure side fuel line before re-installing the supply line or fuel will just dribble out the pressure side fitting. As noted above, replace the line if it shows any signs of deterioration -and given this is a nearly 40-year-old car, it probably should be replaced.
