Electronic Ignition system for pre '75, pros, cons, problems
Old Nov 17, 2016 | 07:32 PM
7T1vette's Avatar
7T1vette
Don't need to carry a spare set of points. When points/condenser start to deteriorate, there is usually some very minor misfiring. Not enough to be troublesome...but enough to let you know to do maintenance. You could run for hundreds of miles like that, before it became a problem; so no difficulty driving it to your garage for 20 minutes of work (every year or so).
If you want to go electronic, have at it. I included my suggestion for that too. Or do you just want to bicker....
Old Nov 17, 2016 | 07:59 PM
Iceaxe's Avatar
Iceaxe
Just pointing out the flaw in your reasoning. I have never had an electronic ignition leave me stranded. Points have once (back in 1974 in my Z-28).
YMMV
Old Nov 17, 2016 | 08:31 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
YMMV
The sheer number of cars produced with both points and a true electronic ignition prove they both work just fine and both can fail at any given time. Threads like this are pointless and change no ones mind. Run what works for you.
Old Nov 18, 2016 | 11:05 AM
Spot Rot's Avatar
Spot Rot
Thanks for the posts, they've been very useful and informative. I've learned a lot about the various systems that's not in their marketing descriptions.
I was most interested in reliability and limitations not disclosed in sale literature.
Old Nov 18, 2016 | 11:48 AM
ddawson's Avatar
ddawson
Breakerless SE here, three years no issue.
Old Nov 18, 2016 | 11:58 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I would not argue that one id more reliable than the other, but I do enjoy not having to set dwell, and advance is all electronic on mine. I also really like the more accurate and stable tach operation from electronic ignition.
Old Nov 18, 2016 | 12:20 PM
Nowhere Man
Corvettes used a disb drive cable for the tach until they went to HEI in 74. How can adding a electronic widget to replace points change that?
If you had five diffreant cars that were indentical expect for ignition that was running in perfect order and kept the hood closed and didn't tell the driver. under normal driving he would never know what created that spark
Old Nov 18, 2016 | 12:27 PM
Kubs's Avatar
Kubs
Earlier in this thread I explained that I changed out for a Mallory MaxFire distributor and converted to an electric tach.
Mine is a probably a little more involved than you want to go, but I converted to a Mallory MaxFire electronic distributor on my '71. It has all the timing control and rev limiter built into it so no need for an external box. I removed the resistance wire and ran a new 12ga pink wire from the bulkhead connector to the distributor. This is exactly how the '75+ HEI cars came from the factory. I did also have to convert to an electronic tach, as there is no tach drive on it. I have the factory one rebuilt with electronic guts by Roger at Corvette Instrument Service in Florida. He did a great job.
Old Nov 18, 2016 | 12:28 PM
LS4 PILOT's Avatar
LS4 PILOT
I've had factory 1974 dated GM HEI dizzy , wires , all stock ignition in my 74 Z28 motor for 8 years now . Never has failed , still has same plugs . Clean as a pin. I'm using a Ruggles rebuilt Quadrajet and stock air cleaner. Btw ....there were TSB s from GM early on that corrected the problems found that first year.
It really is a good system for up to 7000 rpm. .....way more than I'm gonna need.
