Roller rocker comparison
Doing some work to my stock 350 over the next few months.
Build is as follows.
Patriot exhaust headers (Already installed)
XE268H Comp cam
Edelbrock Performer 2101 inlet manifold
Upgraded valve springs and pushrods
Quadrajet carby
Stock converter (2500rpm Hi stall converter installed later)
Roller rockers 1.5 ratio
Stock heads and engine
Only thing I need to buy is the roller rockers. I've got 5 in mind.
Comp cams High energy Aluminium roller rockers. Cost $300AU landed
http://www.ebay.com.au/itm/262571455...%3AMEBIDX%3AIT
PRW Aluminium Pro Series rocker arms self aligning.Cost $340AU landed
http://www.ebay.com.au/itm/131875994...%3AMEBIDX%3AIT
Elgin stainless rocker arms ( these look quite good with a extra large trunnion and very good value for money) Cost 230AU landed
http://www.ebay.com.au/itm/261462891...%3AMEBIDX%3AIT
Comp cams Magnum roller rocker arms self aligning. No Polylocks. Cost $300 landed
http://www.ebay.com.au/itm/150782159...%3AMEBIDX%3AIT
Blumax aluminium roller rocker arms. Cost $315 landed
http://www.ebay.com.au/itm/381219586...%3AMEBIDX%3AIT
All these rockers arm are either for 3/8 or 7/16 stud. I'm not sure which size stud my stock heads will take, presuming they are a 3/8 stud. Could someone tell me what exactly size stud I need rockers for and therefore which studs I need to buy please?
I used these on the first iteration of my build. It says they are good for 350 lbs of open pressure. It's more like 300 lbs. I was running 330# open and it blued the pivot points and wore them out quickly creating excessive rocker lash. Otherwise I liked them. No guide plates needed with the self aligning ones.
3/8" studs are fine for the spring pressure these will run.
These will also fit just fine under stock valve covers.
Some of the aluminum rockers are pretty thick and may interfere with stock rocker covers unless you get a spacer for them.
https://www.summitracing.com/int/par...4-16/overview/
http://www.compperformancegroupstore...ct_Code=981-16
According to the summit listing these have a spring rate of 370 lbs/in. Is spring rate the same as open spring pressure?
I would like to stick with my original valve covers and am happy to use a 5/16 gasket for clearance if I have to. But if they dont fit well I'll have to change the valve covers then.
https://www.summitracing.com/int/par...1-16/overview/
They fit under my oem finned vv covers on stock L-82 heads using two Mr. Gasket Ultra Seal gaskets. On the AFR 195's, only one gasket required, Felpro rubber/steel insert. No mods required to the internal baffles either.
https://www.summitracing.com/int/par...2-16/overview/
But for the sake of only an extra $60US or $90AU maybe I might be better off getting the roller rockers you suggested.
Do these come in a self aligning rocker, doesn't look like it? Any chance these can fit under the standard Corvette valve covers with the polylocks?
I wonder how much valve spring pressure they tolerate. Are you using these with the standard valve springs and what cam installed please mate? I've used Crane stuff before and had no issues also.
If you know the spring pressure at the installed height you can compute the open spring pressure if you know the spring rate (lbs/in) and the lifted height of the valve.
The lifted height of the valve can be computed by taking the lobe lift and multiplying it by your rocker ratio. 1.5 if using standard rocker ratio or 1.6 if using those.
Comp cams lists the valve lift as such with 1.5rr.
That comes out to 177.6 lbs. This is the amount the spring pressure will rise from the seat pressure or closed position of the valve.
Typical on a flat tappet may be in the 80lb to 100lb range for seat pressure.
so say it's 100lbs. 100+177.6=277.6 lbs. That is your open pressure.
To compute your lobe lift on the cam take the valve lift and divide it by 1.5.
.477/1.5=.318 cam lobe lift
.480/1.5=.320 cam love lift
Now with those numbers you can compute your valve lift with any other ratio of rocker. Like 1.6's if you want.
Then with the new valve lift you can compute your new open spring pressure.
https://www.summitracing.com/parts/csp-s1001/overview/
I do recommend you go to 7/16 stud......this gives you room to grow in the future.....
Jebby
Seems the polylocks are the biggest problem for the bulkier rockers.
So take your .480 and multiply it by the spring rate of 370.
Jebby
I know this is a big block, and yours is a small block. I put these rockers on a few years ago, before the rebuild. I was very happy with them.
I think my biggest advice would be to not over-cam it. I see way too many that want a lumpy idle, get a big lift, and big duration, and the motor won't do crap.
I have Brodix heads, I put a Comp Cam roller cam, about .540 lift or so. The range on the cam is idle to 5500. Has a smooth idle and will fry the tires at rolling at 25-35 easy. I haven't had it out yet, the brake booster isn't working, and replacement is coming in a few day.
Here's a link to the cam I'm using and dyno results with Dart SR heads. Not huge lift by any means. Max Lift w/ 1.5RR: .477" / .480"
http://www.compcams.com/v002/Pages/388/XE268H-10.aspx
You're just gonna have to put a sound bite when it's running
I'm not familiar with what you mean by sound bite??
