Starting issue need help
Old Nov 29, 2016 | 12:00 PM
Kyle78vette's Avatar
Kyle78vette
Default Starting issue need help
I just got a new project and I'm not a mechanic. it sat for a long time I was able to get it started when I picked it up now it won't start the battery died and I used a jump box it cranks but won't start not sure if I flooded it or gummed up the carb. the primary jets work not sure on secondaries. any ideas?
Old Nov 29, 2016 | 02:49 PM
MelWff's Avatar
MelWff
Remove all the spark plugs and clean them with carburetor cleaner assuming they dont look like they need replacing.
Does the choke close fully after stepping on the gas pedal fully to the floor and releasing it
After you clean/replace the plugs, step on the gas twice to close the choke and try starting it.
I'm assuming you have a 1978
Old Nov 29, 2016 | 03:18 PM
Kyle78vette
Sometimes stays open and sometimes it closes what is it supposed to do
To Starting issue need help
