1969 COPO Corvette
Old Dec 1, 2016 | 03:49 PM
mpuzach's Avatar
mpuzach
Default 1969 COPO Corvette
I've read articles about the only 1969 COPO Corvette to leave the factory. Here's a link to one:
http://www.corvetteactioncenter.com/..._copo_l88.html
My question is, what was it about this car that required it to be ordered as a COPO and not a regular production order? I've looked at the specs listed and see nothing that seems to have been unavailable as regular production options.
Old Dec 1, 2016 | 03:54 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by mpuzach
...what was it about this car that required it to be ordered as a COPO and not a regular production order?...
Who can say? The M22 was a 69 option and should not have required a COPO. Stranger things have happened. There was a car posted here a while back with a COPO for a non-recommended color combination.
Old Dec 1, 2016 | 03:59 PM
mpuzach's Avatar
mpuzach
Yeah, the non-recommended color combo I can understand. This particular car I cannot.
Old Dec 1, 2016 | 05:37 PM
Lindstrom's Avatar
Lindstrom
Hello mp ..
As I understand it, in 1969, the M22 was an option for the L88. The regular M22 had 2 plugs ... one for fill and one for drain(the M20 and M21 only had 1 plug for fill). The drain plug of the standard M22 was magnetized. It was made by Lisle, and there were 5-6 variations over the life of the M22(fwiw).
In 1969, this car was ordered by Rick Tomkins to have a magnetized plug for fill as well. So, it had 2 magnetized Lisle plugs, thus becoming a special order or COPO.
According to the build sheet for this car, the option looks to be ZW1. I have found other information that indicates ZW1 as a M22, but without a specific reason for the separate option code.
Here's a link ...
http://www.yenko.net/ubbthreads/ubbt...topics/13343/1
Great mystery to spend the winter with ...
Old Dec 1, 2016 | 05:47 PM
CanadaGrant's Avatar
CanadaGrant
Originally Posted by Lindstrom
Hello mp ..
According to the build sheet for this car, the option looks to be ZW1. I have found other information the indicates ZW1 as a M22, but without a specific reason for the separate option code.
Here's a link ...
According to trans guru Paul Cangialosi, in 69 all Muncie's were changed over to dual fill/drain plugs. My 69 with the numbers matching M20 has dual plugs. Hard to believe you would have to go to a COPO just to get a magnetized plug but weirder things have happened....
Old Dec 1, 2016 | 06:03 PM
Lindstrom's Avatar
Lindstrom
Hello Grant ...
Corvette by the Numbers says that happened in 1970. My early build 1969 M20 with matching numbers only had a fill. I had to drill & tap a drain. I suspect the changeover may lie somewhere toward the end of 1969 production ... ??
Old Dec 1, 2016 | 06:21 PM
CanadaGrant
Hello Grant ...
I think you are probably right. He said it was changed in 69 so that could mean almost anything. My build is Oct 24 69. Trans build was Oct 13 and it has the 2 holes. P9R13A.
Old Dec 1, 2016 | 07:02 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
the COPO and FSO was on the same box on the tank sticker. if the car had a trim override it could be a FSO. if its a COPO there should be a engineering drawing of the special part that required it. this is more likely just dealer hype
Old Dec 1, 2016 | 08:16 PM
Lindstrom's Avatar
Lindstrom
Hello Grant ...
I no longer have my 1969 judging manual. Do you know if this issue is addressed NCRS manual-wise, and if so, at what serial number .... ??
Just curious
Old Dec 1, 2016 | 08:25 PM
Lindstrom's Avatar
Lindstrom
Hello Nowhereman ...
I'm not quite understanding what you said there ...
Scroll down and see a copy of the actual M22 tank sheet. It even specifies COPO. If it were a FSO, the tank sticker would so specify ... right?
https://www.proteamcorvette.com/cars/69L88COPO.htm
Old Dec 1, 2016 | 08:46 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
So how much value is added for a magnetized plug?
Old Dec 1, 2016 | 09:04 PM
LT1driver's Avatar
LT1driver
because of the 4.56 axle??
Old Dec 1, 2016 | 09:11 PM
Nowhere Man
for a COPO that required non RPO equipment not called out in the assembly spec and engineered drawings. For a COPO the engineering department would have had to get the spec out parts to build it. Like I said the FSO and COPO used the same box on the build sheet. If you do some searching on here under JohnZ with COPO and I'm sure he explained it better then I did.
Old Dec 1, 2016 | 09:12 PM
Nowhere Man
That was availble under the posi option
Old Dec 1, 2016 | 09:44 PM
mpuzach's Avatar
mpuzach
Hello mp ..
Here's a link ...
This is excellent and interesting information. Thank you for taking the time to post it here.
Old Dec 1, 2016 | 09:45 PM
CanadaGrant
Hello Grant ...
Just curious
Sorry, I don't know. In Cangialosi's book Muncie 4-Speed Transmissions, he says, "By the start of 69 these cases and all future cases had the drain plug boss drilled and threaded."
I thought this meant the 69 model year but I guess it was probably more like the actual 1969 year.
Old Dec 1, 2016 | 11:16 PM
LS4 PILOT's Avatar
LS4 PILOT
Priceless.
Old Dec 2, 2016 | 07:58 PM
Nowhere Man
from the NCRS forum this car is the only L88 that does not have J56 brakes. But that does not make it a COPO. what does it was ordered car was ordered with two magnetized drain/fill plugs as standard M22's in 1969 used only one magnetized plug and the other plug was unmagnitized
To 1969 COPO Corvette
