L36 Build
Old Dec 6, 2016 | 11:13 PM
peterjanke's Avatar
peterjanke
Cruising
Default L36 Build
Very close to starting a rebuild on my 69 L36 air car. I would appreciate any thoughts on how to take advantage of the process to build a more powerful, bullet proof motor that will be strictly a street driver. Perhaps a little aggressive street driver once in awhile, but really a street driver. What about using aluminum parts to get some of the weight out of the front end?
Old Dec 7, 2016 | 10:10 AM
emccomas's Avatar
emccomas
Headers, aluminum heads and intake.
Make sure you match the parts to each other (i.e. no high rpm cam with a low range intake).
Keep us posted.
Old Dec 7, 2016 | 11:24 AM
ddawson's Avatar
ddawson
I built a 496 out of mine.
Aluminum heads, water pump. 1969 intake is already aluminum but I switched it to a Holley setup instead.
Roller cam, Cloyes chain and cover.
To L36 Build
