Another 1980 Body-off
Old Dec 13, 2016 | 09:29 AM
lakerider57's Avatar
lakerider57
Default Another 1980 Body-off
My good friend Craig and I lifted the body off a 1980 corvette over the past weekend. Took about 2 hours to lift off and place on a dolly. I had already done all the prep work.
I used two welded/bolted up square tubing rigs and 4 ***-alongs to lift the body.
I plan to powder coat the frame and put in a 420hp crate engine.
Let me try to share photos with a Google photos link:
https://photos.google.com/share/AF1Q...lwcGVoZE01dHpR
Old Dec 13, 2016 | 09:58 AM
Alan 71's Avatar
Alan 71
Hi l57,
It looks like you had done some good preparation.
Nice set up to lift it too!
At first I thought you'd just reinforced the building's structure, but see the frames you built.
Well Done!
Good Luck!
Regards,
Alan
Old Dec 13, 2016 | 11:59 AM
lakerider57
Originally Posted by Alan 71
Hi l57,
Well Done!
Good Luck!
Regards,
Alan
Hi Alan,
I saw way too many lifting mechanisms that gave me a big pause so when I saw another member on the forum here who used the square channel iron, I thought that was the way to go. Each leg of the lifting mechanism breaks down into 3 pieces with 5/8" bolts and are fully adjustable. The steel is really heavy duty but I plan on keeping these even when the restoration is complete. I did the welding myself with a Hobart 220v welder.
By the way, in North Dallas here, most of the quotes to sand blast and powder coat the frame are in the $600 range which is way cheaper than I thought it would cost.
Richard
Old Dec 13, 2016 | 07:02 PM
bazza77's Avatar
bazza77
looks good, its so true that preparation makes the job so much easier,
car looks in good condition ? no rust? should be a (relatively ) straight forward clean up and rebuild eh ?
are you planning on putting extra welds in the frame with some gusseting ?
Old Dec 14, 2016 | 08:19 AM
lakerider57
Hi Bazza77,
The frame looks very good, my friend Craig did eyeball a crack on the shock mount show below:
Yes, I plan on welding on the frame especially around the body mount brackets and adding some stout gussets in the corners.
Richard
To Another 1980 Body-off
