hi
i have a 81 corvette. the starter motor engages as soon as the key is in the on position, if put in to d or r it stops
any ideas would be a great help
thank
so, the motor starts ok, but dies when you put it in drive or reverse or any gear? correct? what is the idel RPM? new car to you?? a little history of car might help.
Sorry should have explained better. The starter motor turns constantly. Unless put into drive or neutral.i have replace the ign switch which made no difference
Brand new in a box? Because the wipers go bad on the switch and that is one of the symptoms. Are you sure of the wiring being correct, including the solenoid?
The solenoid could be stuck in the engaged position as Tim suggests. If you can while the car is in the air and you are inspecting the wiring, start the engine and tap the solenoid and see if it dis-engages. Make sure the car is on ramps or pined stands, sorry I'm over cautious.
