Build Sheet
Old Dec 24, 2016 | 02:47 PM
EdsAZcar's Avatar
EdsAZcar
1st Gear
Default Build Sheet
Anybody where the build sheet is located on a '69 Corvette
Old Dec 24, 2016 | 02:51 PM
530planeman's Avatar
530planeman
on gas tank or sometimes rolled up behind speedometer
Old Dec 24, 2016 | 02:55 PM
tyrant's Avatar
tyrant
mine was on gas tank but un-readable.
Old Dec 24, 2016 | 03:30 PM
Alan 71's Avatar
Alan 71
Hi Ed,
FIRST POST!!!!
Merry Christmas!
The tank sheet was typically glued to the top of the gas tank.
If you look through the gas door opening with a flash light (pushing down on the the rubber drain boot) you can sometimes see if it's still there.
Look to the right and the left.
IF you see it don't be tempted to try to get it out. The sheet is very fragile and trying to remove it without dropping the tank from the chassis isn't a good idea.
Sometimes an additional copy was tucked into the dashboard between the tachometer and speedometer or above the radio.
Good Luck!
Regards,
Alan
Old Dec 24, 2016 | 04:36 PM
CanadaGrant's Avatar
CanadaGrant
The build sheet on my 69 is located on the drivers side of the gas tank and is visible by pushing down on the rubber drain boot as Alan describes. There is no way to get it off without dropping the tank but it's there and is easy to see.
Old Dec 24, 2016 | 05:01 PM
Kevova's Avatar
Kevova
The assembly line sheets can be anywhere. The more of a virgin the car is the more likely 1 or more sheets will be found. I have found sheets in doors, seats, dash, under carpets, headliners, fuel tanks, and spare tires so happy hunting.
Old Dec 24, 2016 | 06:00 PM
Alan 71's Avatar
Alan 71
Hi K,
You've found build sheets in all those places in 68-82 cars?
Regards,
Alan
Old Dec 24, 2016 | 07:05 PM
Kevova's Avatar
Kevova
In various cars over the years working in dealership service departments. I asked about the saving them the more senior techs said not worry about them. There were multiple sheets used as car came down assembly line. The line workers could shove them anywhere. Didn't find them as often when vin was barcoded in the early nineties.
Old Dec 26, 2016 | 06:48 AM
terrys6t8roadster's Avatar
terrys6t8roadster
When I was installing a steering upgrade while removing the P/S cylinder mount I found it tuck into the frame rail. This was on the 69. T
To Build Sheet
