speakers
Here's the question: since this is the future there is no doubt a wireless solution. My iPhone has my entire music collection in it and I thought a portable bluetooth speaker in back might do the trick. It's a '69 convertible so there isn't a lot of room but a 'can' of some sort should fit. Wouldn't be too hard to provide a 12v source for power if needed.
I use a JBL Charge in the garage and sometimes in my service truck but it doesn't have the onions to produce the sound necessary.
Anybody done this ? Any recommendations on brand, etc ? I've been looking through Crutchfield and marine audio sites and so so forth but thought I'd solicit a few opinions.
And yes, I know those nice sidepipes make all the wonderful sound I should ever need, but ....
All four speakers should have a 4 ohm impedance. The two speakers on each side (R and L) should be wired in SERIES (not in parallel). That would yield a total of 8 ohms impedance on right and on left side. That is a 'good enough' impedance match for the radio output amp...which wants to see 10 ohms. You will have no negative effects with that setup; but the sound quality will be MUCH better and the sound will be much fuller than with just the dash speakers.
P.S. Those dash speakers are still an important part of the system.
Marine audio is where I'm looking. 12v supply is available and they have to overcome a lot of ambient noise.
As for the kick panel speakers, they are priority #152 right now but they are on the list.
I feel that if that old radio has been in there for almost a half century then that's where it will stay. Good enough to listen to a ball game on.
I've bookmarked a couple of places that offer replacement slimline 10ohm speakers. I just want to remove
the existing 6x9 behind the seats before they scuff up the backs of the seats any more.
You're right. I was thinking that only '68s had the kickpanel-only speakers.Well, like the Church Lady in SNL used to say...
"Nevermind..."
To that end, find the best quality LOW POWER (50 watts or less) 8 ohm speakers (2-way types will sound better) that will fit in the kickpanels and connect them up to your original head unit. Make sure both speakers are 'phased' alike.
{Why low power? The amp in the Delco head and convector only had 16 watts RMS. If you connect up some high power/low efficiency speakers, there won't be any power left for sound volume.}
If you can't locate suitable 8 ohm speakers, buy two mid-range/tweeter speakers and two mid-range bass speakers, all four being 4 ohm units. Then wire each side with 2-speaker sets wired in SERIES to get 8 ohms. Again, all speakers need to be properly phased; and the two speakers on each side can fit one above the other behind the kickpanel.
There is also a rear speaker box that is on the C3 sites that sounds ok. They go in the back corners and look original.
