Ignition Sheilding
Old Jan 15, 2017 | 12:48 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Originally Posted by Alan 71
Hi Freddy,
I'm not sure what part you're referring to as the 'chrome brackets'.
With headers on the engine there's no way to mount the 2 horizontal shields (3371 & 3368) or their small supports.
I don't think you can mount the spark plug heat shields (3383 & 6503k) either. Not needed with headers.
You can likely still be able mount the spark plug wire heat shields (14769 &14770)Again, not necessary.
You'll still be able to mount and secure the left side vertical shield (3365), but there will be no lower support for the right side vertical shield (3364).Neither of my vertical shields is supported on the lower end. It still fastens the same at the top. Again, they won't 'flop' around and cause any issues at least in my experience with headers
Regards,
Alan
Yes, for the most part.
Old Jan 15, 2017 | 06:00 PM
Freddy76's Avatar
Freddy76
Thanks for your time. I don't have the lower heat shields. I only have the brackets , the chrome vertical brackets and the top cover. I wasn't sure if I needed the lower shields also.
Old Jan 15, 2017 | 10:59 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
"You'll still be able to mount and secure the left side vertical shield (3365), but there will be no lower support for the right side vertical shield (3364).
Regards,
Alan "
This is the important part.
Old Jan 17, 2017 | 11:15 AM
Freddy76's Avatar
Freddy76
I was able to put on the brackets. But it seems the plug wires are tight in the grommets. I may have to get a different and longer plug wire set.
Old Jan 17, 2017 | 01:28 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
The grommets are nice but aren't necessary to run the the plug wires unless you are looking for originality.
Old Jan 17, 2017 | 05:38 PM
Alan 71's Avatar
Alan 71
Hi F76,
I realize you're using headers…. how are you routing the wires?
If you're referring to the length of the spark plug wires…. yes they may be too short.
Or are you meaning that the wires seem to be too big a diameter for the opening in the grommets?
And, which grommets?
Regards,
Alan
Does this help at all?
It's the right side showing the typical wire routing.
The 2 forward plug wires are going into the boomerang heat shield.
The 2 rear wires are headed to the rear 2 plugs.
The rear spark plug heat shield is in place.
The 2 small brackets are in place for the rear radio shielding.
The left side.
2 wires going to the rear plugs.
2 going into the boomerang toward the forward plugs.
Old Jan 19, 2017 | 08:22 AM
Freddy76's Avatar
Freddy76
Alan,
Thanks for the photographs. Have you ever considered publishing a pictorial of your restoration ? Your photographs are so clear and precise.
Old Jan 19, 2017 | 08:45 AM
Tooch1's Avatar
Tooch1
Hi F76,
Regards,
Alan
The left side.
Hi Alan,
You're slipping a little my friend I notice on your clutch cross shaft that it has the grease fitting present and not the 'Red Plastic Plug' , "C'mon man!!"
Just messing with you, you know that! ( I'm sure it was present for judging.)
Great pics as always
Tooch
Old Jan 19, 2017 | 04:56 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Alan,
I'm convinced Alan has a dozen vettes in various stages of disassembly being able to provide all his pics in short time to post here!!!
