C3 Caliper bolts
Old Jan 1, 2017 | 10:42 AM
Z06LMB's Avatar
Z06LMB
Default C3 Caliper bolts
The prior owner rounded off the bolt heads so I chucked them in the can. Now I'm back to work on this car and
I thought I had a few of these saved from another set, however I was wrong. What size are these bolts? Threads per inch? Course threads?
Thank you for your help
Old Jan 1, 2017 | 10:55 AM
Tampa Jerry's Avatar
Tampa Jerry
Default Bolts
Are you referring to the bolts holding the calipers together or the bolts that mount the caliper to the flange? In any event, the bolts are grade 8. As for the sizes, check the websites for Van Steel and Vette Brakes and Products. The bolts are the same for all 66 to 82 vettes. Jerry
Old Jan 1, 2017 | 10:57 AM
Alan 71's Avatar
Alan 71
Hi Z,
The front and rear caliper mounting bolts are 7/16"x20x1-1/8". Grade 8.
Regards,
Alan
Old Jan 1, 2017 | 11:34 AM
Z06LMB's Avatar
Z06LMB
Originally Posted by Alan 71
Hi Z,
Regards,
Alan
Alan, thank you so much for your quick answer!
Old Jan 1, 2017 | 11:44 AM
Z06LMB's Avatar
Z06LMB
Jerry, it's the long bolts (sorry, I should have been more specific)--------
Thanks for the help!
Old Jan 1, 2017 | 12:03 PM
Antz81's Avatar
Antz81
Long bolts are 9/16-18 (UNF) grade 8. Sorry I can't remember the length. I think 2-1/2" but that could be wrong.
Old Jan 1, 2017 | 12:20 PM
Alan 71's Avatar
Alan 71
Hi a,
A's surmise was very close.
The fasteners for the caliper halves are 2-7/16" long.
They appear to be specific for that use because of the length of the unthreaded portion of the bolt.
Regards,
Alan
To C3 Caliper bolts
