seat fix
Old Jan 2, 2017 | 04:48 PM
buelldude's Avatar
buelldude
Default seat fix
So here is a few questions about C3 seats
The mounting brackets for the seats, how do I put new ones on the rails?
The rear bolt holes were drilled out and big bolts & nuts used to keep the seat in place. Is there a fix to the hole to go back to the proper size bolt?
Old Jan 2, 2017 | 05:23 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If memory, the feet are spot welded to the adjusters.
Old Jan 3, 2017 | 03:50 AM
buelldude's Avatar
buelldude
pulled part of the seat and it seems to be a rivet, this could be easy???? The hold down bolts are going to be the big ones to fix. I hope its just the one, pb blaster is my friend.
To seat fix
