Steering shaft alignment
Old Jan 7, 2017 | 11:17 AM
retiredrey's Avatar
retiredrey
Default Steering shaft alignment
How much misalignment is allowable between the shaft (column) and the steering box shaft using a rag joint ?
Old Jan 9, 2017 | 10:56 AM
MelWff's Avatar
MelWff
why would there by any misalignment? Are you replacing it or someone previously incorrectly replaced it?
Old Jan 9, 2017 | 12:32 PM
Alan 71's Avatar
Alan 71
Hi Rey,
Are you using the original steering column?
The AIM indicates that the the splined end of the shaft should be slid into the upper end of the rag joint BEFORE any of the column mounting bolts at the firewall or cowl mounted support bracket are tightened.
Can you still do that?
Regards,
Alan
Old Jan 10, 2017 | 12:22 PM
retiredrey's Avatar
retiredrey
Originally Posted by Alan 71
Hi Rey,
Regards,
Alan
Well yes if it be needed. but I think it will work as is. With things "finger" tight the alignment is now quit good.
Rey
To Steering shaft alignment
