Its the gage bezel top screw that goes into the dash pad. I can't use a nut on the other side because there is no room. I tried a bigger screw but it didn't fit in the bezel. I think my only option is JB weld.
Get some gorilla glue and foil tape .put a rag below hole in case glue drops .
Squirt some glue in hole and tight away put tape over it until next day then remove tape and I used a sheet metal screw with counter sunk screw head
Very common problem
Wes
Very common problem
Wes
Fill the original hole with JB Weld stick-type putty epoxy (10 minute hardening), then redrill for mating with self-tapping sheet metal screw. [Note: You might want to 'dry fit' the bezel in place and use the screw hole to locate the best position for the patch to be drilled.] You can just install the screw ONLY (you might put a very light wipe of lubricant on the screw threads so the screw won't stick to the epoxy), then let the epoxy fully cure overnight. Remove the screw and install bezel.
Others have pressed a small, plastic drywall screw retainer into the existing hole (maybe with an adhesive smeared on the outside of it) and allow to fully cure. Then install bezel using the proper screw.
I did that on my 80. I went to home depot and got some of the plastic fasteners that you put into the wall for hanging pictures. Glued it into the dash and put the screw in. I could take remove the screw out and not worry about stripping it.
