68 non ac heater?
Can anyone tell me if this is actually a 68 non ac system?
I was under the impression that 68 systems were cable operated, but this chap assures me that they had vacuum ports..
http://www.ebay.com.au/itm/232202192...&ul_noapp=true
Many thanks!
Dave
Looking at it perhaps he removed form a '68 that had been retro-fitted. I had no problem using the cable system from my '68 in a '69.
Many thanks!
Dave
My original(late) 68 has that same system part vacuum part cable
Wes
The non AC system is pretty simple.
My 68 is also a late one, so if a part vacuum one is correct in yours Wes, it's probably right for mine too!
I've got that page relating to the cables/vents... But nothing on the inner heater box etc!
http://www.camaros.org/AIM.shtml
Many thanks!
Dave
I apologize I may have been thinking of my 70 .I will remove the right dash on my non a/c and get a picture .part of getting old and working on e2 corvettes at once.
Wes
https://www.corvetteforum.com/forums...right-now.html
No vacuum controls for heater system.
Many thanks!
Dave
Many thanks!
Dave
Original late 68<br/>Wes
68 heater control
Dave hope this helps
Wes
CAUTION: This may all be wrong; maybe applies to 69+?
The heater/defroster installation is shown in the AIM (71) in UPC 1, Sheets M1 through M7. Perhaps it's in a similar location in the 68 AIM.
The Bowden cable that is operated by the RIGHT side thumb wheel of the controller opens/closes the heat door in the heater box so is the only temperature control for the system.
The vacuum manifold that is operated by the LEFT side thumb wheel of the controller manages the flow of air in the heater box….. floor duct, defroster duct, or both.
Regards,
Alan
The lever of the hot/cold door with it's Bowden cable connection.
One of the vacuum pot connections that controls air flow direction.
You are correct no vacuum on 68
Wes
Whilst it might end up taking more effort to get the right fittings, I'm secretly thankful that it is cable operated - simple mechanical force feels more diy user friendly than another vacuum system!
Unrelated to previous ask; but same category!
Just test fitting the heater blower assy to see if it clears the headers - but slightly puzzled at the whooping great gap at the end where the heater core pipes come out... should the gap really be like this? (With no core or inside box)
