10si alternator or 12si....
Old Jan 28, 2017 | 09:04 PM
540 vette's Avatar
540 vette
Default 10si alternator or 12si....
10si or 12si alternator. What is the difference. I don't have an alternator in my 72 right now and I am buying a 100 amp.
Old Jan 29, 2017 | 12:18 AM
ajrothm's Avatar
ajrothm
12 si is obviously bigger.
Are you wanting a stock case 100 amp or a new smaller style 100 amp?
Most of us running electric fans ended up converting to a CS144 alternator from an early 90s caddy/impala etc.. If you are using factory big block alternator brackets, the lower bracket will need to be cut/rewelded to accomodate the 144. This is truly the best up grade if you have a lot of electric draw.
I have pics if you need em.
Old Jan 29, 2017 | 09:02 AM
540 vette's Avatar
540 vette
Stock case.
Old Jan 29, 2017 | 11:44 AM
zwede's Avatar
zwede
12SI charges better at low rpm. I wouldn't buy a "100A" alternator without seeing the charging curve. It may charge 100A 5,000 rpm, but worse than a stock alternator at low rpm..
Old Jan 29, 2017 | 05:46 PM
ajrothm's Avatar
ajrothm
http://store.alternatorparts.com/727...lternator.aspx
Here is a 12SI, 140 amp high output alternator that is 3 wire like the factory alternator. It is the same size case as a 10SI and should fit your stock brackets without modding. If you are wanting a 10/12SI case, this is the guy to go through.
I got my CS144 from him back 7 years ago/19k miles and its still working strong. It charges great at 800 rpms and I have a LOT of electric load... Hell my fan alone is 35 amps continuous.
I still think a CS144 would be more reliable for a 140 amp as it cools better, bigger case, bearings etc but.... I'd bet the 12SI will be fine .
Old Jan 29, 2017 | 08:13 PM
540 vette's Avatar
540 vette
Thanks for the suggestions guys. I bought one from Summit today. I had the same one in my 80 and it worked fine. So I thought it would work good in this car. I just have the electric fans.
To 10si alternator or 12si....
