Headlights
Old Feb 1, 2017 | 10:28 PM
Bob_Irish's Avatar
Bob_Irish
Navigator
Default Headlights
Hey guys, first post here and I'm looking for help. I have to replace my headlight bulbs and I'm not too sure what too look for, if the entire light has to come out or if i can just replace the bulb inside the light. Thanks in advance.
Old Feb 1, 2017 | 11:50 PM
Antz81's Avatar
Antz81
Raise the headlights up, Then remove the bezel (4 screws, 2 top , two side). From there you can remove the retaining ring for each lamp that needs replacing. once the retaining ring has been removed you can remove the bulb.
Old Feb 1, 2017 | 11:58 PM
TimAT's Avatar
TimAT
You may be thinking about later model stuff that has a bulb "inside" a housing. C3, they are one piece old school stuff. And be careful- that retainer ring around the bulb can be sharp.
Old Feb 2, 2017 | 12:13 AM
Bob_Irish's Avatar
Bob_Irish
Navigator
So its that entire circular light that i need to replace then/
Old Feb 2, 2017 | 01:11 AM
Antz81's Avatar
Antz81
Old Feb 2, 2017 | 01:14 AM
Bob_Irish's Avatar
Bob_Irish
Navigator
Good website to order them from? Or on the off chance they are available in stores?
Old Feb 2, 2017 | 06:31 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Get halogen bulbs, they are a lot brighter. Got mine from Summit less than 10$ each. T
Old Feb 2, 2017 | 08:07 AM
gbvette62's Avatar
gbvette62
What you need are 5 3/4" round H5006 sealed beam bulbs, for the outer (low beam) lamps, and 5 3/4" round H5001 sealed beam bulbs for the inner high beams.
The 82 Corvette was the last production car to use the 4 round bulb system, so they are getting harder to find, but you should still be able to pick them up in any auto parts store. Around here, Walmart still carries them.
Old Feb 2, 2017 | 09:22 AM
Alan 71's Avatar
Alan 71
Hi Bob,
Once you raise the headlights and remove the 4 small screws that hold the headlight bezel in place you'll see ring and screws that A81 described.
Pretty straight forward then.
Regards,
Alan
Upper screw is for AIMING the headlight, lower screw is one of those that holds the ring in place.
Old Feb 2, 2017 | 02:32 PM
Bob_Irish's Avatar
Bob_Irish
Navigator
Awesome thanks for the help everyone. I'm sure this won't be my last post looking for help but its great to know I can count on everyone here.
Old Feb 3, 2017 | 02:14 PM
USAFVeteran's Avatar
USAFVeteran
Not to start an argument, but y'all keep saying 4 screws, and my 69 has 3, as well as the pics that Alan posted too.
What gives, is a later model different?
Never mind, I know what you're saying now. The bezel, surround, what ever it's called
To Headlights
